Hopefully this is in the correct place.
My setup is:
Mega 2560
Ethernet Shield
NeoPixel strips of 30/M and 60/M
Running the Artnet_NeoPixel library. GitHub - natcl/Artnet: An Art-Net library for Teensy, Arduino and ESP boards
Everything works great. I'm using some 30 LED per meter strips. The software on my computer sends the Artnet packets to the Arduino and the correct colors come out in the right place. My problems comes that I'm trying to add some new 60 LED per meter strips. It would also be great if I could use more than one of the Arduino output pins, and set a DMX universe to each pin. Universe 0, pin 6. Universe 1, pin 7. Universe 2, pin 8. And so on.
Is it possible to edit this library to behave in such a way?
// Neopixel settings
const int ledsPerStrip = 60; // change for your setup
const byte dataPin = 6;
Adafruit_NeoPixel leds = Adafruit_NeoPixel(ledsPerStrip, dataPin, NEO_GRB + NEO_KHZ800);
// Artnet settings
Artnet artnet;
const int startUniverse = 0; // CHANGE FOR YOUR SETUP most software this is 1, some software send out artnet first universe as zero.
const int numberOfChannels = ledsPerStrip * 3; // Total number of channels you want to receive (1 led = 3 channels)
byte channelBuffer[numberOfChannels]; // Combined universes into a single array
Any easy way to add dataPin 7 and set it to startUniverse 1? Edit: Oh yeah, and set a second var to ledsperstrip2 = 120?
