When I upload a sketch using the online arduino ide, it gives this error:
Executing command: exec: not started
and then in the terminal it says
Flashing with command:{runtime.tools.avrdude.path}/bin/avrdude.exe -C{runtime.tools.avrdude.path}/etc/avrdude.conf -patmega328p -carduino -PCOM4 -b57600 -D -Uflash:w:C:/Users/Stuart/AppData/Local/Temp/arduino-create-agent768995181/sketch_oct7a.hex:i
not sure why this is happening because I used it a couple of days ago and worked fine. Also when I use the arduino ide I get this:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x63
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
