Arudino Uno + Stepper + IMU - Timing Problem
Hello Guys!
I'm having a problem combining my IMU with my stepper motor. I know it is a timing problem for sure. I have tried using milis() but didn't got it to work.. The speed of the stepper motor is very slow and is not increasing at all.
I would like to increase the speed of the stepper dependent of the value given by the IMU.
IMU Calculation alone -> Works perfect
Stepper alone -> Works perfect
Maybe someone could help me, it is driving me crazy.
I am using a CNC Shield (TMC2209 Driver) with Nema17 and a BMI160 IMU
I have attached my code:
#include <BMI160Gen.h>
#include <PID_v1.h>
#include <AccelStepper.h>
#define BAUDRATE  115200
// Sensor Data
#define SENSE_RATE   100
#define GYRO_RANGE   250
#define ACCL_RANGE     2
#define deg_to_rad(a) (a/180*M_PI)
#define rad_to_deg(a) (a/M_PI*180)
#define motorInterfaceType 1
double MotorspeedX = 0;
const int8_t i2c_addr = 0x69;
unsigned long startMillis;  //some global variables available anywhere in the program
unsigned long currentMillis;
const unsigned long period = 0.0001;
//Stepper Motors
//X-Axis:
const int DirX1 = 6;
const int StepX1 = 3;
//const int StepX2 = 4;
//const int DirX2 = 7;
//Y-Axis:
//const int StepY1 = 2;
//const int DirY1 = 5;
//const int StepY2 = 12;
//const int DirY2 = 13;
AccelStepper myStepperX1(motorInterfaceType, StepX1, DirX1);
/*AccelStepper myStepperX2(motorInterfaceType, StepX2, DirX2);
  AccelStepper myStepperY1(motorInterfaceType, StepY1, DirY1);
  AccelStepper myStepperY2(motorInterfaceType, StepY2, DirY2);
//Convert Raw Sensor Data
float convertRawGyro(int gRaw) {
  // ex) if the range is +/-500 deg/s: +/-32768/500 = +/-65.536 LSB/(deg/s)
  float lsb_omega = float(0x7FFF) / GYRO_RANGE;
  return gRaw / lsb_omega;  // deg/sec
float convertRawAccel(int aRaw) {
  // ex) if the range is +/-2g ; +/-32768/2 = +/-16384 LSB/g
  float lsb_g = float(0x7FFF) / ACCL_RANGE;
  return aRaw / lsb_g;
static float gyro_roll = 0, gyro_pitch = 0, gyro_yaw = 0;
static float comp_roll = 0, comp_pitch = 0;
static unsigned long last_mills = 0;
// PID
double SetpointY, InputY, OutputY;    // PID variables
double SetpointX, InputX, OutputX;    // PID variables
double P = 600;
double I = 0;
double D = 0;
PID myPIDY(&InputY, &OutputY, &SetpointY, P, I, D, DIRECT);    // Y axis PID
PID myPIDX(&InputX, &OutputX, &SetpointX, P, I, D, DIRECT);    // X Axis PID
double deadSpot = 200;
void print_roll_pitch()
  // read raw accl measurements from device
  int rawXAcc, rawYAcc, rawZAcc; // x, y, z
  BMI160.readAccelerometer(rawXAcc, rawYAcc, rawZAcc);
  float accX = convertRawAccel(rawXAcc);
  float accY = convertRawAccel(rawYAcc);
  float accZ = convertRawAccel(rawZAcc);
  float rad_a_roll = atan2(accY, accZ);
  float rad_a_pitch = atan2(-accX, sqrt(accY * accY + accZ * accZ));
  float accl_roll = rad_to_deg(rad_a_roll);
  float accl_pitch = rad_to_deg(rad_a_pitch);
  //Read raw gyro measurments:
  int rawRoll, rawPitch, rawYaw; // roll, pitch, yaw
  BMI160.readGyro(rawRoll, rawPitch, rawYaw);
  float omega_roll  = convertRawGyro(rawRoll);
  float omega_pitch = convertRawGyro(rawPitch);
  float omega_yaw   = convertRawGyro(rawYaw);
  unsigned long cur_mills = micros();
  unsigned long duration = cur_mills - last_mills;
  last_mills = cur_mills;
  double dt = duration / 1000000.0; // us->s
  if (dt > 0.1) return;
  // Gyro data
  gyro_roll  += omega_roll  * dt; // (ms->s) omega x time = degree
  gyro_pitch += omega_pitch * dt; //Y
  gyro_yaw   += omega_yaw   * dt; //Z
  // Complementary filter data
  comp_roll  = 0.93 * (comp_roll  + omega_roll  * dt) + 0.07 * accl_roll;     //X-Axis
  comp_pitch = 0.93 * (comp_pitch + omega_pitch * dt) + 0.07 * accl_pitch;    //Y-Axis
  InputX = comp_roll;
  myPIDX.Compute();
  MotorspeedX = OutputX;
  //Motorsteuerung X......
  InputY = comp_pitch;
  myPIDY.Compute();
  //Motorsteuerung Y......
  myStepperX1.setSpeed(OutputX);
  myStepperX1.runSpeed();
    if (OutputY >= deadSpot) {
      myStepperY1.setSpeed(OutputY);
      myStepperY2.setSpeed(OutputY);
    else if (OutputY <= deadSpot) {
      myStepperY1.setSpeed(0);
      myStepperY2.setSpeed(0);
  /*  Serial.print(comp_roll);
    Serial.print("/");
    Serial.print(comp_pitch);
    Serial.print("/");
    Serial.print(OutputY);
    Serial.print("/");
    Serial.print(OutputX);
    Serial.print("/");
    Serial.print(SetpointY);
    Serial.print("/");
  myStepperX1.setMaxSpeed(4000);
  myStepperX1.setSpeed(0);
  BMI160.begin(BMI160GenClass::I2C_MODE, i2c_addr);
  /*  pinMode(StepX1,OUTPUT);
      pinMode(DirX1,OUTPUT);
      pinMode(StepX2,OUTPUT);
      pinMode(DirX2,OUTPUT);
      pinMode(StepY1,OUTPUT);
      pinMode(DirY1,OUTPUT);
      pinMode(StepY2,OUTPUT);
      pinMode(DirY2,OUTPUT);
  //  myStepperX2.setMaxSpeed(5000);
  //  myStepperX2.setSpeed(4000);
  // myStepperY1.setMaxSpeed(5000);
  // myStepperY2.setMaxSpeed(5000);
  BMI160.setGyroRate(SENSE_RATE);
  BMI160.setAccelerometerRate(SENSE_RATE);
  BMI160.setGyroRange(GYRO_RANGE);
  BMI160.setAccelerometerRange(ACCL_RANGE);
  BMI160.autoCalibrateGyroOffset();
  BMI160.autoCalibrateAccelerometerOffset(X_AXIS, 0);
  BMI160.autoCalibrateAccelerometerOffset(Y_AXIS, 0);
  BMI160.autoCalibrateAccelerometerOffset(Z_AXIS, 1);
  SetpointY = 0;     // Desired value for PID loops
  SetpointX = 0;
  myPIDY.SetMode(AUTOMATIC);
  myPIDY.SetOutputLimits(-4000, 4000);    // limits for PID loops
  myPIDX.SetMode(AUTOMATIC);
  myPIDX.SetOutputLimits(-4000, 4000);
  print_roll_pitch();
A link to the datasheet of the stepper would be helpful.
What kind of stepping is used? Any microstepping?
They are standard Nema17 motors. No micro stepping yet but I plan to switch to microstepping when the program works.
Okey, no mictostepping. Good.
Nema17 is a mechanical classification. It tells nothing about the electrical data. Anyway, more current doesn't affect speed. Too little current and the stepper stops sounding like a buzzer.
No Pc available for the moment but more documentation is needed.
I don't find where/how OutputX is computed.
Lot's of heavy float math.
How is acceleration set for Accelstepper?
I will search for the Datasheet but the problem are not the stepper motors or the electrical data.
OutputX is computed by the PID library. But it is not important to understand. I have stripped down the code and deleted everything unnecessary.
The problem is for sure the timing because the IMU is blocking the Stepper. If I uncomment this line: "BMI160.readAccelerometer(rawXAcc, rawYAcc, rawZAcc);" the stepper motor runs with the speed I want.
If I add the IMU-read the Stepper is very slow. I just don't know how to solve the timing problem..
#include <PID_v1.h>
// Sensor Data
//Stepper Motors
//X-Axis:
  myStepperX1.setSpeed(4000);
//---------------------------------If i don't read the IMU Values everything works great----------------//
  print_roll_pitch();
Good. I fiddled with a phone, now a tablet and it cuts off the view.
You're likely on the right track, that some call goes to a blocking function.
One ide could be to serial.println(millis()) before and after suspected calls as long as millis is less than 5 - 10 seconds.
I don't know that sensor, if it can be operated in a faster way or change of sensor is better.
I'm sure there are helpers knowing.
