Arudio mega Device Descriptor request failed
Hello forum
I have som problem with my arduino. I think that i fried somethink.
The code that i upload is working properly.
But when i pluged arduino to my PC to change some think in code windows says "Unknown USB Device (Device Descriptor Request Failed)" before my accident when i think touched arduino with wire it was working properly.
CH340G is working, i checked 3.3V supply is working aswell.
The the easiest is to buy new arduino but i dont have that much money on me.
How can i find what component is fried quickly ?
Can any one help?
from your description, you must have damaged the CH340G.
If you are skilled at desoldering/soldering SMD components, I suggest changing the CH340G.
If not, I suggest you ask someone to do it or buy a new mega
Thank you for reply
So if i change CH340G, arduino should work like before. Am i correct?
Better question is. There is no other component broke just this USB gate ?
We can't make an absolute diagnosis from the little bit of information you supplied.
Was this a 140V mains?
We can only guess what you did to it, if anything...
As @ruilviana stated, you might be smart to have someone do it for you. It requires proper de-soldering equipment to replace a smd properly... and successfully.
If you can't afford a new mega, you probably don't have the proper equipment... and there is no guarantee that will fix it.
As a suggestion, don't fiddle with the wiring with the power on...
Good luck
:smiley_cat:
There is no problem in desoldering or soldering i can do it in school i just dont want waste money on new arduino when new component is just for 2€
But thank you for help
Makes sense.. :slight_smile:
:smiley_cat:
Hello
While ago i burned somethink on my arduno i replace ch340 bcs i didnt see any device connected to my pc
Now i see device but cant upload or see any msg in serial monitor.
What else can be damaged?
The devil is in the details. we need some.
Maybe you can find it here.
Leo..
wow bud- is it the same board?
I have merged your topics due to them having too much overlap on the same subject matter @skrix.
In the future, please only create one topic for each distinct subject matter and be careful not to cause them to converge into parallel discussions.
The reason is that generating multiple threads on the same subject matter can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Thanks in advance for your cooperation.
yeah it is same board
sorry my bad
i will be carefull in future
