I have a problem with trying to receive string data from AS3. It is being sent as a socket.writeUTFBytes. I am not sure what I am missing. In the Arduino code below, I am expecting three various strings from the serial, U, D, and motor###. This works great in the serial monitor, but not when sending anything from Flash to the serial socket. Can someone please direct me toward the right direction?
#include <stdio.h>
#include <Stepper.h>
const int pwmA = 3;
const int pwmB = 11;
const int brakeA = 9;
const int brakeB = 8;
const int dirA = 12;
const int dirB = 13;
const int steps = 200;
Stepper myStepper(steps, dirA, dirB);
int led = 6;
pinMode(led, OUTPUT);
myStepper.setSpeed(100);
// Turn on pulse width modulation
pinMode(pwmA, OUTPUT);
digitalWrite(pwmA, HIGH);
pinMode(pwmB, OUTPUT);
digitalWrite(pwmB, HIGH);
// Turn off the brakes
pinMode(brakeA, OUTPUT);
digitalWrite(brakeA, LOW);
pinMode(brakeB, OUTPUT);
digitalWrite(brakeB, LOW);
Serial.println("OK");
char command[1024];
char commandBuffer[128];
int commandBufferSize = 0;
void readCommandBuffer(int bytesToRead) {
int i = 0;
char c = 0;
while (i < 128 && (i < bytesToRead || bytesToRead <= 0)) {
while (!Serial.available())
c = Serial.read();
if (c == '\r' || c == '\n') {
commandBuffer[i] = c;
i++;
commandBufferSize = i;
void readCommand() {
command[0] = '\0';
readCommandBuffer(0);
if (strncmp(commandBuffer, "RCV", 3) == 0) {
commandBuffer[commandBufferSize] = '\0';
int expectedSize = atoi(commandBuffer + 4);
if (expectedSize <= 0 || expectedSize > 1024) {
return;
Serial.println("RDY");
int bytesRead = 0;
while (bytesRead < expectedSize) {
readCommandBuffer(expectedSize - bytesRead);
memcpy(command + bytesRead, commandBuffer, commandBufferSize);
bytesRead += commandBufferSize;
Serial.print("ACK ");
Serial.println(commandBufferSize);
command[bytesRead] = '\0';
memcpy(command, commandBuffer, commandBufferSize);
command[commandBufferSize] = '\0';
while(Serial.available() == 0);
//readCommand();
//Serial.println(command);
readCommand();
String str = String(command);
Serial.println(str);
if(str.indexOf("motor") >= 0){
int newPosition = str.substring(5,str.length()).toInt();
myStepper.step(newPosition);
digitalWrite(pwmA, LOW);
digitalWrite(pwmB, LOW);
}else{
if(str == "U"){
digitalWrite(led, HIGH);
} else if(str == "D"){
digitalWrite(led, LOW);
