Der Sketch sieht so aus:
AS3935 | ESP8266 (NodeMCU)
MISO/SDA | D3
MISO | GND
SCK/SCL | D4
IRQ | D5
SI | +3,3V
CS | GND
GND | GND
Vdd | +3,3V
#include <AsyncDelay.h>
#include <SoftWire.h>
#include <AS3935.h>
#define SDA_PIN D3
#define SCL_PIN D4
#define IRQ_PIN D5
AS3935 as3935;
bool ledState = true;
AsyncDelay d;
void int2Handler(void)
as3935.interruptHandler();
void readRegs(uint8_t start, uint8_t end)
for (uint8_t reg = start; reg < end; ++reg) {
delay(50);
uint8_t val;
as3935.readRegister(reg, val);
Serial.print("Reg: 0x");
Serial.print(reg, HEX);
Serial.print(": 0x");
Serial.println(val, HEX);
Serial.flush();
Serial.print("State: ");
Serial.println(as3935.getState(), DEC);
Serial.println("-------------");
void setup(void)
as3935.initialise(SDA_PIN, SCL_PIN, 0x03, 3, true, NULL);
as3935.start();
d.start(1000, AsyncDelay::MILLIS);
while (!d.isExpired())
as3935.process();
readRegs(0, 0x09);
as3935.setNoiseFloor(0);
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, ledState);
pinMode(IRQ_PIN, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(IRQ_PIN), int2Handler, RISING);
Serial.println("setup() done");
uint8_t count = 0;
void loop(void)
if (as3935.process()) {
uint8_t flags = as3935.getInterruptFlags();
uint8_t dist = as3935.getDistance();
Serial.println("-------------------");
Serial.print("Interrupt flags: ");
Serial.println(flags, HEX);
Serial.print("Distance: ");
Serial.println(dist, DEC);
if (as3935.getBusError())
Serial.println("Bus error!");
if (as3935.getTriggered())
Serial.println("Triggered!");
if (d.isExpired()) {
ledState = !ledState;
if (++count > 5) {
count = 0;
readRegs(0, 0x09);
Die Ausgabe ist dann immer "triggert":
PORT OPEN 115200
Communication with MCU..Got answer! Communication with MCU established.
AutoDetect firmware...
Can't autodetect firmware, because proper answer not received (may be unknown firmware).
Please, reset module or continue.
Reg: 0x1: 0x22
Reg: 0x2: 0xC2
Reg: 0x3: 0x0
Reg: 0x4: 0x0
Reg: 0x5: 0x0
Reg: 0x6: 0x0
Reg: 0x7: 0x3F
Reg: 0x8: 0x3
State: 4
setup() done
Reg: 0x0: 0x24
Reg: 0x1: 0x2
Reg: 0x2: 0xC2
Reg: 0x3: 0x0
Reg: 0x4: 0x0
Reg: 0x5: 0x0
Reg: 0x6: 0x0
Reg: 0x7: 0x3F
Reg: 0x8: 0x3
State: 5
Interrupt flags: 1
Distance: 63
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Interrupt flags: 1
Distance: 63
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
Triggered!
So wie ich vermute, liegt es wohl am IRQ handling, leider aber sehe ich nicht, wo der Fehler liegen könnte?
Das ist die verwendete Libary.
