Since you asked: code in progress:
// LightningDetector_Boxed.ino
// Based on AS3935MI_LightningDetector_I2C.ino by Gregor Christandl
// (Use AS3935MI library with the lightning sensor connected using I2C)
// Lightning detector without display, using only buzzer and LEDs.
// Current code: Michael Willems, michael@willems.ca
// Rev 1.3, 2021-07-24
// Connect the AS3935 to the Arduino like this (using short as possible connections):
// Arduino - AS3935
// 5V ------ VCC
// GND ----- GND
// D2 ------ IRQ Pin supporting external interrupts, e.g. D2 or D3 on an Arduino Uno.
// SDA ----- MOSI A4 on an Arduino Uno
// SCL ----- SCL A5 on an Arduino Uno
// 5V ------ SI (activates I2C for the AS3935)
// 5V ------ A0 (sets the AS3935' I2C address to 0x11) // <--(board does this)
// 5V ----- A1 (sets the AS3935' I2C address to 0x11) //<--(board does this)
// 5V ------ EN_VREG !IMPORTANT when using 5V Arduinos (Uno, Mega2560, ...) //<--(board does this)
// other pins left unconnected.
// INCLUDES AND DEFINITIONS:
//The Lighning Detector stuff:
#include <Arduino.h>
#include <Wire.h>
#include <AS3935I2C.h> // the detector board's library
#define PIN_IRQ 2
//create an AS3935 object using the I2C interface, I2C address 0x11 and IRQ pin 2:
AS3935I2C as3935(AS3935I2C::AS3935I2C_A11, PIN_IRQ);
volatile bool interrupt_ = false; //this value will be set to true by the AS3935 interrupt service routine.
//The Rest:
unsigned long counter; // for flashing on-board LED 13 with 1s frequency
unsigned long yellowcounter; // for brief yellow flash (= disturber/QRM or noise/QRN)
unsigned long bluecounter; // for brief blue flash (= lightning) - may be replaced by white LED...
byte sw3up = 3;
byte sw3upBefore = 3;
byte lowsens = 3;
int flashactive = 0;
int stormdist = 0; // Distance to storm as reported by the chip
int heartbeat = 13; // for LED 13 slow flash to indicate alive
int green = 3; // "passed tests and operating" LED
int red = 4; // error LED
int yellow = 5; // Disturber LED
int blue = 6; // Lightning LED, can also be white ;-)
int pushbutton = 7; // to reset the blue latch LED
int beeper = 8;
int redbar1 = 9;
int redbar2 = 10;
int redbar3 = 11;
int redbar4 = 12;
void(* resetFunc) (void) = 0; // Reset function, to reset after a week (recalibrate, [& avoid millis rollover])
// SETUP (RUNS ONCE):
pinMode (heartbeat, OUTPUT);
pinMode (red,OUTPUT);
pinMode (green,OUTPUT);
pinMode (yellow,OUTPUT);
pinMode (blue,OUTPUT);
pinMode (pushbutton, INPUT_PULLUP);
pinMode (beeper, OUTPUT);
pinMode (redbar1,OUTPUT);
pinMode (redbar2,OUTPUT);
pinMode (redbar3,OUTPUT);
pinMode (redbar4,OUTPUT);
pinMode (A1, INPUT); //switch 1: on/off
pinMode (A2, INPUT); //switch 2: enable beep
pinMode (A3, INPUT); //switch 3: spare
digitalWrite (green, HIGH);
digitalWrite (red, HIGH);
digitalWrite (yellow, HIGH);
digitalWrite (blue, HIGH);
digitalWrite (redbar1, HIGH);
digitalWrite (redbar2, HIGH);
digitalWrite (redbar3, HIGH);
digitalWrite (redbar4, HIGH);
digitalWrite (green, LOW);
digitalWrite (red, HIGH); // Red LED stays on, to indicate initializing phase.
digitalWrite (yellow, LOW);
digitalWrite (blue, LOW);
digitalWrite (redbar1, LOW);
digitalWrite (redbar2, LOW);
digitalWrite (redbar3, LOW);
digitalWrite (redbar4, LOW);
while (!Serial); //wait for serial connection to open (only for testing)
//set the IRQ pin as an input pin. Do not use INPUT_PULLUP.
pinMode(PIN_IRQ, INPUT);
Wire.begin();
// Now we check that the detector is on, connected and functioning:
// begin() checks Interface and I2C Address passed to the constructor & resets AS3935 to defaults.
if (!as3935.begin())
Serial.println("begin() failed. Check I2C address passed to the AS3935I2C constructor. ");
flashred(1); // flash red LED once
while (1);
//check I2C connection:
if (!as3935.checkConnection())
Serial.println("checkConnection() failed. Check I2C connection and I2C Address. ");
flashred(2); // flash red LED 2x: I2C Failed
while (1);
else {
Serial.println("I2C connection check passed. ");
//check the IRQ pin connection:
if (!as3935.checkIRQ())
Serial.println("checkIRQ() failed. check if the correct IRQ pin was passed to the AS3935I2C constructor. ");
flashred(3); // flash red LED 3x: IRQ failed.
while (1);
else {
Serial.println("IRQ pin connection check passed. ");
//calibrate the resonance frequency. failing the resonance frequency could indicate an issue
//of the sensor. resonance frequency calibration will take about 1.7 seconds to complete.
int32_t frequency = 0;
if (!as3935.calibrateResonanceFrequency(frequency))
Serial.print("Resonance Frequency Calibration failed: is ");
Serial.print(frequency);
Serial.println(" Hz, should be 482500 Hz - 517500 Hz");
flashred(4); // flash red LED 4x: Calibrating resonance freq. failed.
while (1);
else {
Serial.println("Resonance Frequency Calibration passed. ");
Serial.print("Resonance Frequency is "); Serial.print(frequency); Serial.println(" Hz");
//calibrate the RCO.
if (!as3935.calibrateRCO())
Serial.println("RCO Calibration failed. ");
flashred(5); // flash red LED 5x: Calibrating RCO failed.
while (1);
else{
Serial.println("RCO Calibration passed. ");
//set the analog front end to 'indoors'
as3935.writeAFE(AS3935MI::AS3935_INDOORS);
//set default value for noise floor threshold
as3935.writeNoiseFloorThreshold(AS3935MI::AS3935_NFL_2); // Noise Floor, ...NFL_2 Default
//set the default Watchdog Threshold
as3935.writeWatchdogThreshold(AS3935MI::AS3935_WDTH_2); // Watchdog Threshold, ...WDTH_2 default
//set the default Spike Rejection
as3935.writeSpikeRejection(AS3935MI::AS3935_SREJ_2); // Spike rejection, ...SREJ_2 default
//write default value for minimum lightnings (1)
as3935.writeMinLightnings(AS3935MI::AS3935_MNL_1);
//mask disturbers or not
as3935.writeMaskDisturbers(false);
//the AS3935 will pull the interrupt pin HIGH when an event is registered and will keep it
//pulled high until the event register is read.
attachInterrupt(digitalPinToInterrupt(PIN_IRQ), AS3935ISR, RISING);
Serial.println("Initialization complete, waiting for events...");
digitalWrite(red,LOW); // turn off red "initializing" LED
digitalWrite(green,HIGH); // turn on green LED to indicate passed test; operating now.
counter = millis();
digitalWrite (beeper, HIGH);
delay(5);
digitalWrite (beeper, LOW);
delay(500); //now we're all set to start.
// LOOP (LOOPS CONTINUOUSLY):
// we stay in this loop until an interrupt happens.
if (millis() > 604800000) { //reset after a week: recalibrate filter [& avoid millis rollover]
resetFunc();
if (digitalRead(A1) == HIGH) { //if switch 1 is high, we are asleep, so: exit. We loop like this until
return;
else {
if ((millis() - counter) > 1000) { // we do our "once a second" stuff
counter = millis();
digitalWrite (heartbeat,!(digitalRead(heartbeat))); //flash on board LED on/off slowly (running check):
// Now we check if sw3 has changed position:
// If so, change sensitivity accordingly ("up" = high)
// check sw3 position:
if (digitalRead(A3) == HIGH) {
sw3up = 0;
else {
sw3up = 1;
// now check if it is time to check if sw3 has changed:
if (sw3up != sw3upBefore) {
//do whatever, the state has changed
if (sw3up == 1) {
//make it sensitive
delay (100);
lowsens=0; //right now, does not do anything...
// as3935.writeSpikeRejection(AS3935MI::AS3935_SREJ_2); // Spike rejection, ...SREJ_2 default
// as3935.writeMinLightnings(AS3935MI::AS3935_MNL_1); // minimum lightnings in 15 min = 1
else {
//make it less sensitive
delay (100);
digitalWrite (red, LOW);
lowsens=1; //right now, does not do anything...
// as3935.writeSpikeRejection(AS3935MI::AS3935_SREJ_3); // Spike rejection, ...SREJ_2 default
// as3935.writeMinLightnings(AS3935MI::AS3935_MNL_5); // minimum lightnings in 15 min = 5
//now reset the switch 3 watchdog:
sw3up = 0;
sw3upBefore = 0;
else {
sw3up = 1;
sw3upBefore = 1;
} //ok, we have set sensitivity if needed (if switch changed).
if ((millis() - yellowcounter) > 50) { // if yellow LED is on, turn it off after 50ms
digitalWrite (yellow,LOW);
// "check for pushbutton and if it is pushed, turn off blue"
if ((millis() - bluecounter) > 50) { // if buzzer is on, turn it off after 50ms
digitalWrite(beeper, LOW); //turn off buzzer
if (digitalRead(pushbutton) == LOW) {
digitalWrite (blue,LOW);
if (interrupt_) {
//the Arduino should wait at least 2ms after the IRQ pin has been pulled high
delay(2);
//reset the interrupt variable:
interrupt_ = false;
//query the interrupt source from the AS3935:
uint8_t event = as3935.readInterruptSource();
if (event == AS3935MI::AS3935_INT_NH){
// NOISE/QRN
yellowcounter = millis();
digitalWrite(yellow,HIGH);
Serial.print("QRN INTERRUPT: ");
Serial.print(event);
Serial.print(" at ");
Serial.println (millis());
else if (event == AS3935MI::AS3935_INT_D) {
// DISTURBER/QRM
Serial.print("QRM INTERRUPT: ");
else if (event == AS3935MI::AS3935_INT_L) {
//LIGHTNING DETECTED
stormdist = (as3935.readStormDistance());
// Now let's display the bar to indicate distance (more LEDs is closer):
if (stormdist <11) {
displaybar (4); // close by, flash 4 bar LEDS
else if (stormdist < 21) {
displaybar (3); // kinda close, flash 3 bar LEDs
else if (stormdist < 31) {
displaybar (2); // not that clase; flash 2 bar LEDs
else {
displaybar (1); // not close, so flash 1 bar LED
digitalWrite(blue,HIGH); // turn on blue LED (until button pressed)
Serial.print("LIGHTNING INTERRUPT! ");
Serial.print(stormdist);
Serial.print("km away, at ");
else {
//UNKNOWN EVENT
Serial.print("UNKNOWN INTERRUPT: ");
Serial.println(event);
// FUNCTIONS:
// ISR (interrupt service routine). this function
// is called each time the AS3935 reports
// an event by pulling the IRQ pin high.
#if defined(ESP32)
ICACHE_RAM_ATTR void AS3935ISR()
interrupt_ = true;
#elif defined(ESP8266)
interrupt_ = true;
#else //we're using an Arduino Uno, etc
void AS3935ISR()
interrupt_ = true;
#endif
//Flash the red LED "a" times, and repeat 10
// times, to indicate error condition:
void flashred (int a) {
for (int r=0; r<10; r++) {
for (int i=0; i<a; i++) {
digitalWrite(red, HIGH);
delay(250);
digitalWrite(red, LOW);
delay(250);
delay(2000);
//display the bar graph (1-4)
void displaybar (int a) {
if (a<1) {
a=1;
if (a>4) {
a=4;
if (a==1) {
else if (a==2) {
delay (4);
else if (a==3) {
delay(4);
delay(4);
else if (a==4) {
delay(4);
delay(4);
delay(4);
if (digitalRead(A2)==LOW) {
delay(100);
delay(380);
delay(140);
delay(200);
delay(260);
