Hi guys! I need your help!
I’m gonna use a sensor (https://www.embeddedadventures.com/datasheets/AS3935_Datasheet_EN_v2.pdf).
It works with i2c and spi interfaces. I need to use it with the i2c interface, but the library (AS3935 library ) uses the i2c.h (i2c.h library) instead of the wire.h .
The differences are 2:
the i2c.h library has two functions used in the sensor’s library
uint8_t I2C::read(uint8_t address, uint8_t registerAddress, uint8_t numberBytes)
bytesAvailable = 0;
bufferIndex = 0;
if(numberBytes == 0){numberBytes++;}
nack = numberBytes - 1;
returnStatus = 0;
returnStatus = start();
if(returnStatus){return(returnStatus);}
returnStatus = sendAddress(SLA_W(address));
if(returnStatus)
if(returnStatus == 1){return(2);}
returnStatus = sendByte(registerAddress);
if(returnStatus)
if(returnStatus == 1){return(3);}
if(returnStatus)
if(returnStatus == 1){return(4);}
returnStatus = sendAddress(SLA_R(address));
if(returnStatus)
if(returnStatus == 1){return(5);}
for(uint8_t i = 0; i < numberBytes; i++)
if( i == nack )
returnStatus = receiveByte(0);
if(returnStatus == 1){return(6);}
if(returnStatus != MR_DATA_NACK){return(returnStatus);}
returnStatus = receiveByte(1);
if(returnStatus != MR_DATA_ACK){return(returnStatus);}
data[i] = TWDR;
bytesAvailable = i+1;
totalBytes = i+1;
returnStatus = stop();
if(returnStatus)
if(returnStatus == 1){return(7);}
and
uint8_t I2C::write(uint8_t address, uint8_t registerAddress, uint8_t data)
returnStatus = 0;
if(returnStatus)
if(returnStatus)
returnStatus = sendByte(data);
if(returnStatus)
if(returnStatus)
that are not present in the wire.h .
How can I solve this problem? Thank you in advance!
