Hi everyone , i connected my RFID to connect to flash with serialproxy.
But may i know is there ways to when i tap a tag card i can trace something in flash?
import net.eriksjodin.arduino.Arduino; import net.eriksjodin.arduino.events.ArduinoEvent; import net.eriksjodin.arduino.events.ArduinoSysExEvent; import flash.utils.ByteArray; import flash.events.Event;
var a:Arduino; var numEvents:Number=0;
// connect to a serial proxy on port 5331 a = new Arduino("127.0.0.1", 5331);
// listen for connection a.addEventListener(Event.CONNECT,onSocketConnect); a.addEventListener(Event.CLOSE,onSocketClose);
// listen for firmware (sent on startup) a.addEventListener(ArduinoEvent.FIRMWARE_VERSION, onReceiveFirmwareVersion);
// listen for data a.addEventListener(ArduinoEvent.ANALOG_DATA, onReceiveAnalogData); a.addEventListener(ArduinoEvent.DIGITAL_DATA, onReceiveDigitalData);
//listen for sysex messages a.addEventListener(ArduinoSysExEvent.SYSEX_MESSAGE, onReceiveSysExMessage);
// triggered when a serial socket connection has been established function onSocketConnect(e:Object):void { trace("Socket connected!"); // request the firmware version a.requestFirmwareVersion();
// triggered when a serial socket connection has been closed function onSocketClose(e:Object):void { trace("Socket closed!"); }
// trace out data when it arrives... function onReceiveAnalogData(e:ArduinoEvent):void { trace((numEvents++) +" Analog pin " + e.pin + " on port: " + e.port +" = " + e.value); }
// trace out data when it arrives... function onReceiveDigitalData(e:ArduinoEvent):void { trace((numEvents++) +" Digital pin " + e.pin + " on port: " + e.port +" = " + e.value); }
// trace incoming sysex messages function onReceiveSysExMessage(e:ArduinoSysExEvent) { trace((numEvents++) +"Received SysExMessage. Command:"+e.data[0]); }
// the firmware version is requested when the Arduino class has made a socket connection. // when we receive this event we know that the Arduino has been successfully connected. function onReceiveFirmwareVersion(e:ArduinoEvent):void { trace("Firmware version: " + e.value); if(int(e.value)!=2) { trace("Unexpected Firmware version encountered! This Version of as3glue was written for Firmata2."); } // the port value of an event can be used to determine which board the event was dispatched from // this is one way of dealing with multiple boards, another is to add different listener methods trace("Port: " + e.port);
// do some stuff on the Arduino... initArduino(); }
function initArduino():void { trace("Initializing Arduino");
// set a pin to output a.setPinMode(13, Arduino.OUTPUT);
// set a pin to high a.writeDigitalPin(13, Arduino.HIGH);
// turn on pull up on pin 4 a.writeDigitalPin(4, Arduino.HIGH);
// set digital pin 4 to input a.setPinMode(4, Arduino.INPUT);
// enable reporting for digital pins a.enableDigitalPinReporting();
// disable reporting for digital pins //a.disableDigitalPinReporting();
// enable reporting for an analog pin a.setAnalogPinReporting(3, Arduino.ON); // set a pin to PWM a.setPinMode(11, Arduino.PWM);
// disable reporting for an analog pin //a.setAnalogPinReporting(3, Arduino.OFF);
// write to PWM (0..255) a.writeAnalogPin(11, 255);
// trace out the most recently received data //trace("Analog pin 3 is: " + a.getAnalogData(3)); //trace("Digital pin 4 is: " + a.getDigitalData(4));
The above is Simpleio.fla i trying to add this , but it dun work
function onTag(evt:Arduino):void{
//reading tagnumber numberRead.appendText( evt.Data + "\n"); numberRead.scrollV = numberRead.length ; //to see the last line entered vScrollBar.update();
//here from the tag numbers the images are found //prepare tagnumbers and images in special folder var myImageName : String = ""; if( evt.Data == "0c002b13e2" ) myImageName = "1.jpg"; if( evt.Data == "17004aba59" ) myImageName = "2.jpg"; if( evt.Data == "1300482f36" ) myImageName = "3.jpg";
