ASCII ART for MCU
Hey guys,
I'm often writing code for an ATmega328P that replaces non-working Zilog OTP chips by way of a socket adapter.... I used to spend a lot of time flipping from the zilog pin map, to the ATmega pin map to the socket adapter schematic... Eventually, I made a little pin map in ASCII that I could place at the top of each program. It has saved me countless hours. I thought I might share it with you. Although you may have no use for the zilog stuff, please feel free to modify it for your use.
/*  ---Pin Constants Map---
  Z8,003   Pin Name               Pin#  +-----+  Pin#        Pin Name        Z8,003
                          /RESET  (  )--¦     ¦--(19)  PC5   DoorLimitPin    PA4
  J2, PB4                    RXD  ( 0)--¦     ¦--(18)  PC4   CycleStartPin   PA5
  PB1                        TXD  ( 1)--¦  A  ¦--(17)  PC3   EjectorPin      PA6
  PA3      LatchPin          PD2  ( 2)--¦  T  ¦--(16)  PC2   CoolPumpPin
           NotUsedPin[0]     PD3  ( 3)--¦  m  ¦--(15)  PC1   SinkDataPin     PA2
  PA1      ClockPin          PD4  ( 4)--¦  e  ¦--(14)  PC0   CoilPin         PA7
  5VDC                       VCC  (  )--¦  g  ¦--(  )  GND
  GND                        GND  (  )--¦  a  ¦--(  )  AREF
                           XTAL1  (  )--¦  3  ¦--(  )  AVCC
                           XTAL2  (  )--¦  2  ¦--(13)  SCK   NotUsedPin[3]
  PA0      SourceDataPin     PD5  ( 5)--¦  8  ¦--(12)  MISO  NotUsedPin[2]
  J1, PB4  CycleDonePin      PD6  ( 6)--¦  P  ¦--(11)  MOSI  NotUsedPin[1]
  PB2      AnalogCompPin    AIN1  ( 7)--¦     ¦--(10)  PB2   EnablePin       PB3
  PB0      NotUsedPin[0]     PB0  ( 8)--¦     ¦--( 9)  OC1A  CalibrationPin
