ASCII characters in the Serial Monitor
Hello, it's me again. Sorry for making multiple posts so close together. :confused:
For an assignment in my introductory microprocessors class, I have to create a program that reads a phrase typed into the serial monitor and prints how many vowels are in said string.
I've seen a lot of examples online about how to do this with integers, but I can't seem to figure out how to make it work with letters.
Please let me know if you have any ideas. Thank you!
 /* HW 3: Vowel Count
 * Adapted from https://www.arduino.cc/en/Serial/Read
char input = 0;
int count = 0;
int countA = 0;
int countE = 0;
int countI = 0;
int countO = 0;
int countU = 0;
int counta = 0;
int counte = 0;
int counti = 0;
int counto = 0;
int countu = 0;
 Serial.begin( 9600 );
       count = 0;
        while ( Serial.available() == 0 )
          input = Serial.read();
          delay ( 3000 );
          Serial.print (input);
          Serial.print (" ");
          if ( input = 65 )
          count = count++;
          if ( input = 69 )
          count = count++;
          if ( input = 73 )
          count = count++;
          if ( input = 79 )
          count = count++;
          if ( input = 85 )
          count = count++;
           if ( input = 97 )
          count = count++;
           if ( input = 101 )
          count = count++;
          if ( input = 105 )
          count = count++;
           if ( input = 111 )
          count = count++;
          if ( input = 117 )
          count = count++;
      if (count > 0)
      Serial.print (count);
      Serial.println (" vowel(s)");
      delay (200);
Well, first of all, you have a "phrase" of unknown length coming to the Serial port, yet you allow for only a single character to be moved from the buffer to your 'input". You must have storage for the entire phrase.
Then you wait 3 seconds for what?
Paul
Thanks for getting back to me.
Do you mean that I need a string to read it? I thought that might be the case, but we had not talked about that in class yet when this was assigned.
The delay was left over from previous troubleshooting, sorry.
audiojulie:
I suspected that was the case for the delay.
Please review the tutorial on reading serial data : Serial Input Basics - updated - Introductory Tutorials - Arduino Forum.
That should help a bit.
Paul
hint 1: watch your "=" vs "==" !
hint 2: in C, a single ascii character inside single quotes has an integer value equal to the ascii value of the character.
So "if (input == 97)" can be written as "if (input == 'a')"
If you need to print how many vowels you have you only need 1 count, and just check any incoming char against the vowels (small caps or not - what about Y?). Print the result when you receive ‘\n’ for example
What are those for then
int countA = 0;
int countE = 0;
int countI = 0;
int countO = 0;
int countU = 0;
int counta = 0;
int counte = 0;
int counti = 0;
int counto = 0;
int countu = 0;
This - in plain English -
would read as « while I don’t have anything to read, try to read it anyway ».... how successful do you think that is likely to be?
(plus the = versus == etc)
audiojulie:
char input = 0;
int count = 0;
int countA = 0;
int countE = 0;
int countI = 0;
int countO = 0;
int countU = 0;
int counta = 0;
int counte = 0;
int counti = 0;
int counto = 0;
int countu = 0;
You define all of them, but never use them.
      count = 0;
          delay ( 3000 );
          Serial.print (" ");
if ( input = 65 )
Three errors.
  1. you reset count to 0 every time loop runs. So it can never go past 1.
  2. you only run this when there's nothing to read. Replace the while line with:
if (Serial.available()) {
This will run the block when you have something on the Serial buffer: read the character and process it.
          if ( input = 65 )
And this one of course.
If you don't care about which vowel but just want to count them all you can do this in a single if statement:
if (input == 'a' || input == 'e' || input == 'i') { // fill in the rest
  count++;
if (input == '\n') { // newline character terminates the input.
  Serial.print("Vowels counted in this input: ");
  Serial.println(count);
  count = 0;
Never put a delay() when you deal with Serial input - don’t second guess asynchronous behavior with synchronous code
Would suggest you read Serial Input Basics
Just a quick note: an ASCII coded number minus ASCII number ‘0’ is the number in decimal.
