ASCII, RS232, Serial
Hello,
I have a Freetronics 11 R3, which is apparently 100% Ardunio compatable.
Does this device out of the box have the capability to monitor a serial port of RS232 ASCII output or do I need to purchase an additional PCB for this board?
I would like to be able to wait for commands and have the Ardunio switch a Freetronics relay which I already have.
Thanks :slight_smile:
Depends on whether it is a real RS232 port or is actually a 'TTL/logic level' output labelled as RS232.
If it has a 9 or 25 pin connector then it may be a real RS232 port in which case you need an RS232 to TTL/logic level converter. If in doubt use a converter as putting RS232 voltages into an Arduino will damage it.
mikb55:
Thanks for your reply.
The device has a 9pin DB9 input, its an 8 channel RS232 relay.
So I'll asume as you mentioned I'll need the RS232 converter then.
Thanks
Bagel282:
Are you talking about this relay.png 8-channel relay board which works on I2C Protocol.
If you are talking about the quoted relay board, please post a link to the device specification.
GolamMostafa:
Hello,
I'm looking at this board on ebay -
Cheers
1. Yes! I understand that this is your RS232 based 8-channel relay board. If possible, please post the schematic diagram of this relay board.
2. You need the following RS232-TTL Module between Arduino and Relay Board.
