azzabcd
September 29, 2012, 1:25pm
#1
I'm trying to concatenate some values to display the temperature on an LCD screen and I'm having trouble adding the º symbol.
Here is my code:
void DisplayTemp(char temp1[6], char temp2[6]){
char degreSymbol[1] = {223};
strcpy(lcdLine0, "Panel: ");
strcat(lcdLine0, temp2);
strcat(lcdLine0, degreSymbol);
strcat(lcdLine0, "C");
Serial.println(lcdLine0);
DisplayLCD(lcdLine0,lcdLine1);
The results are:
1- On the serial display: Panel: -10.01ß##C
2- On the LCD screen: Panel: -10.01º##C
a- Why are both result different?
b- Where the ## is coming from?
Before I was doing the same thing with strings it was creating error so now I'm trying to use char.
Thanks for your help
pYro_65
September 29, 2012, 1:30pm
#2
this is a pointer with out array an index ( )
why not
char degreSymbol = 223;
"C" is a string ( char array ), however 'C' is a character literal
... and try 248 rather than 223.
system
September 29, 2012, 2:44pm
#4
azzabcd:
In the ASCII encoding scheme values up to 127 are universal. There are multiple definitions for the values above 127 and you need to know which definition (usually referred to as a 'code page') is being used in order to interpret them. The symptoms suggest that the Arduino Serial monitor and the LCD are not using the same code page - one is interpreting your ASCII code to mean the symbol you intended, and the other isn't.
TCWORLD
September 29, 2012, 2:55pm
#5
The ## is coming from the fact that your degree symbol is not a null terminated string so strcat keeps going until it finds a 0. Try this:
char degreSymbol[] = {223,0};
Or better still, this:
char degreSymbol[] = {223,'C',0}; //print degrees C all in one go, means you don't need this: "strcat(lcdLine0, "C");"
Hey, many thanks for everybody. It took me some time, but weith your suggestions, I've been able to do exactly what I was trying.
Thanks again
