ASCII to PDU
I'm using this source code I found online in an attempt to convert ASCII strings in to 7 bit PDU arrays. When compiled I get the following error.
 In function 'int convert_ascii_to_7bit(char*, char**)':
error: invalid operands of types 'int' and 'char**' to binary 'operator*' In function 'int ascii_to_pdu(char*, unsigned char**)':
Does anyone have an idea of what might be wrong?
 * Functions for converting between an ISO-8859-1 ASCII string and a
 * PDU-coded string as described in ETSI GSM 03.38 and ETSI GSM 03.40.
 * This code is released to the public domain in 2003 by Mats Engstrom,
 * Nerdlabs Consulting. ( matseng at nerdlabs dot org )
 * Use a lookup table to convert from an ISO-8859-1 string to
 * the 7-bit default alphabet used by SMS.
 *  *scii   The string to convert
 *  **a7bit  A pointer to the array that the result is stored in,
 *           the space is malloced by this function
 *  Returns the length of the a7bit-array
 *  Note:  The a7bit-array must be free()'ed by te caller
static int convert_ascii_to_7bit(char *ascii, char **a7bit) {
    int r;
    int w;
    int len;
    r=0;
    w=0;
    /* Allocate sufficient memory for the result string */
    len = strlen(ascii)*2+1
    *a7bit=malloc(len);
    while (ascii[r]!=0) {
        if ((lookup_ascii8to7[(unsigned char)ascii[r]])<256) {
            (*a7bit)[w++]=abs(lookup_ascii8to7[(unsigned char)ascii[r++]]);
            (*a7bit)[w++]=27;
            (*a7bit)[w++]=lookup_ascii8to7[(unsigned char)ascii[r++]]-256;
    /* Realloc the result array to the correct size */
    *a7bit=realloc(*a7bit,w);
    return w;
What does the call to this function look like? What are the types of the arguments?
