ASCII to string [SOLVED!!]
Hello all,
I need a conversion from ASCII numbers to the characters they represent, to put into a string. Unless I'm missing something, there are no keywords for this conversion? I'm pretty sad. If there is no other way, am I stuck making a huge code to do it for me?
Sincerely,
-Englishscone
Give an example of what you have. Are all the codes in hexadécimal on 2 digits ? Where do you get them from?
I'm so sorry, I'm quite a beginner with character work.
The numerical ASCII values are easily accessed from my code, they are stored in EEPROM. So by simply calling EEPROM.read(x), I can find the ASCII number, like 115.
J-M-L:
I'm so sorry, I only lightly understand what hexadecimal is.
Thank you for your help!
Englishscone:
Englishscone:
What's "ASCII numbers"? What's "numerical ASCII values"?
The only meaningful idea of "ASCII numbers" I can come up with is when these numbers are already represented by a string. In that case you don't need to do anything.
Montmorency:
The
ASCII numbers did come from a string, perhaps there is a way?
Just put the EEPROM.read(x) into a char type variable instead of a byte and when you print it you’ll see the corresponding character
J-M-L:
Thank you! Should I do it like this?:
char y = EEPROM.read(x);
Serial.println(y);
J-M-L:
You fixed my problem!, I changed my fix to:
char y = char(EEPROM.read(5));
Serial.println(y);
I will enjoy updating you karma! Have a wonderful day!
Thank you so much!
-Englishscone
Great !
