ASCII to Text on Arduino
Hi guys i have a MFRC522 set up and reading blocks from it and writing to serial using Serial.write()
but i want to convert this ASCII bytes to Text
like
065 114 100 117 105 110 111
to Text
Arduino
on the board it self is there any way to do this using a library
please help me in this
Use Serial.print() ?
sterretje:
Serial.write() gives
Arduino
Serial.print() gives
Sorry for misunderstanding.
Store the bytes in an array, add a '\0' (nul terminator) and print. Something like below
byte data[] = {65, 114, 100, 117, 105, 110, 111};
  Serial.begin(57600);
  // text buffer
  char text[sizeof(data) + 1];
  // clear if (fill with nul terminators)
  memset(text, '\0', sizeof(text));
  // copy data to text
  memcpy(text, data, sizeof(data));
  // print it
  Serial.println(text);
sterretje:
// text buffer
  // print it
i had to remove the operator + and trim to get the right result
Thank You it helped me a lot
thanks again
Arduino
065 is ASCII '5'
TheMemberFormerlyKnownAsAWOL:
065 is ASCII '5'
Mmmm, maybe in octal, but then octal would not show as plain "111" would it?
Expand<](http://www.asciitable.com/index/asciifull.gif)
Mmmm definitely 065 (==5310 == 0x65) is '5'
akash614:
thanks again
You shouldn't. You need one byte more for a terminating nul character in the text. You can't print a text (c-ctring) without a terminating nul; you are lucky it works but it is wrong without it.
sterretje:
i had made few changes to the code and it works flawless and meets my requirement so thanks all of you guys for responding to this topic
and Sorry for late reply
Thank You all Once Again
