ASCII vs Text
Hi
I wrote basic code to recieve a string and print it on screen.
String color;
  if(Serial.available()){
    color = (Serial.read());
    Serial.print(color);
I type "red". It prints the ASCII numbers for it(114101100). How can I get it to print "red" rather than the ASCII code?
That's apparently how String deals with creating a String from an int.
To create get it to treat the value as a character it may be as simple as casting to char:
color = (char) Serial.read();
Alternatively you could get rid of the String and just print the character:
    Serial.print(Serial.read(), CHAR);
You also have to make a for loop if you want to make color = "red"
N314: ``` [glow=yellow,2,300]String color;[/glow]
void loop() {   if(Serial.available()){     color = (Serial.read());     Serial.print(color);   } }
String is an object. string is a char string, which is an array.
Since you aren't catting the characters together, in this case, define color as a char.
Simple code to capture what is sent from the serial monitor as a string.
// zoomkat 7-30-11 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
String readString;
  Serial.println("serial test 0021"); // so I can keep track of what is loaded
  while (Serial.available()) {
    delay(1);  //delay to allow byte to arrive in input buffer
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    readString="";
