asin(x) always returns x
I'm trying to get angles from accelerometer/gyroscope and i'm recieving float numbers from that sensor via bluetooth(Serial1) between +1 and -1. I want to get angle from that numbers so i tried using asin() function and it always returns number that i put in instead of radians.
code:
#include <math.h>
double x;
double y;
Serial1.begin(115200);
if(Serial1.available() > 0)
x = Serial1.parseInt();
if (x == 1)
goto w;
x = Serial1.parseFloat();
w:
y = asin(x);
Serial.println(y);
I tried to use float insted of double and all combinations of both.
y always has value of x....why?
I stopped reading at the goto. Eliminate that, and I might look at it.
asin(x) ~ x (in radians, for small x).
Same for sin(x).
aarg:
#include <math.h>
double x;
double y;
y = asin(x);
Serial.println(y);
Here is the code without goto. Thanks for your help.
Use code tags, and tell us what "x" is.
jremington:
Same for sin(x).
Sin of an angle is always between +1 and -1. arcsin uses sin of an angle and converts it in in an angle so it alwas uses small numbers. And in a manual of math.h it says that error occurs when number is between +1 and -1. How can I not use small numbers?
We know what sin() and asin() do. We don't know what your "x" is.
nogi_13:
#include <math.h>
double x;
double y;
y = asin(x);
Serial.println(y);
No, I meant fix it, not just take it out. The structured equivalent code is:
double x;
double y;
   if (x != 1)
      y = asin(x);
   Serial.println(y);
It is not necessary to do #include <math.h>, the IDE includes it by default.
nogi_13:
I assume that you mean "when a number is not between +1 and -1". Also your code doesn't check that.
Try this program:
  int i;
  float x;
  for (i=0; i<10; i++) {
    x = i/10.;
    Serial.print("x = ");
    Serial.print(x);
    Serial.print(" asin(x) = ");
    Serial.println(asin(x));
void loop(){
aarg:
Yes i wrote it wrong.
like this?
double sin_of_angle;
double angle;
sin_of_angle = Serial1.parseInt();
if (sin_of_angle == 1)
angle = asin(sin_of_angle);
Serial.println(angle);
sin_of_angle = Serial1.parseFloat();
if (sin_of_angle != 1)
nogi_13:
I don't know how to not use goto
The answer is in reply #7.
Did you perhaps mean:
if (x > -1 and x <1)?
jremington:
Try this program:
int i;
  float x;
    x = i/10.;
    Serial.print(x);
void loop(){
Ooooh, thanks, I see now what you meant by small numbers, I'm getting radians now with that program, and my program. I'm just convert that to angles now. :slight_smile:
aarg:
I've edited my code, I made mistakes. Serial.parseFloat returned 0 when it should return 1, so I used Serial.parseInt() to detect 1. I got an answer to my question, thanks for your help anyway :slight_smile: .
