Recently I was learning about filters, and I also read a lot of articles about filters on the Internet, but now I have a question I would like to ask you.
Ask for help designing an active bandpass filter.
Claim:
Design a second-order bandpass filter using an op amp
2, the operation uses +-10V DC power supply voltage
3, bandpass filter center frequency 1khz, bandwidth 1khz, gain Av=2
Available devices:
Op amp miuA741×1
Eight-legged chip socket × 1
10k resistance × 2
1k resistance × 2
0.1 micro F capacitor × 2
1 micro F capacitor × 1
10k potentiometer × 2
Diode × 2
Zener diode 5.1V×2
Thank you all.
1kHz center with 1kHz width sounds more like a low-pass filter with a roll-off at 2kHz.
If there is an Arduino involved, just do the filter digitally. Put a simple analog filter in front to ensure there is no frequency higher than half your sample frequency and then do the detailed filtering in software.
Go to http://t-filter.engineerjs.com to design the digital filter. It writes C code which can be easily pasted into Arduino.
