[ASK] Windows Phone And Arduino Uno with Bluetooth HC-05
Hello .. :D i'm so confused about Windows Phone And Arduino Communication Via Bluetooth .. I am confused where to start first .. I learned from some forum but I do not understand, because it is not described in detail .. Maybe here I can get an answer :drooling_face:
The depends entirely on how much your phone is like any other windows computer. If it really is, then it should be able to run a plain-vanilla terminal programme like RealTerm.
You might find the following background notes useful
http://homepages.ihug.com.au/~npyner/Arduino/GUIDE_2BT.pdf http://homepages.ihug.com.au/~npyner/Arduino/BT_2_WAY.ino
Nick_Pyner: The depends entirely on how much your phone is like any other windows computer. If it really is, then it should be able to run a plain-vanilla terminal programme like RealTerm.
Thanks for reply, but for now i can control arduino & Bluetooth HC-05 Using Windows Form Application Using Visual Studio. And i'm now very confused about windows phone Program to connect my bluetooth arduino :roll_eyes:
ARRIVE: but for now i can control arduino & Bluetooth HC-05 Using Windows Form Application Using Visual Studio.
I assume you are doing this on a Windows computer and the "Windows Form Application Using Visual Studio." cannot run on the phone
Sounds like a windows phone problem and I would have thought this is just a matter of going to the Windows phone app store just like it is with an Android phone. You are the only windows phone user I have heard of on this forum. The doesn't mean there are no others but they are very quiet, and you might be better off checking a windows phone forum.
The simplest solution may turn out to be getting an Android phone.
Nick_Pyner:
I assume you are doing this on a Windows computer and the “Windows Form Application Using Visual Studio.” cannot run on the phone
Sounds like a windows phone problem and I would have thought this is just a matter of going to the Windows phone app store just like it is with an Android phone. You are the only windows phone user I have heard of on this forum. The doesn’t mean there are no others but they are very quiet, and you might be better off checking a windows phone forum.
ummm ok …but, Just a little windows phone developer by Arduino , I just want to make it different with other Phone. :slight_smile:
