Asking user for new value if condition is false
Hello all I have a mini project where i have to ask the user to input a positive value if its negative the user has to input a different value
I have
Int N;
Serial.print(“Enter value:”);
while(Serial.available ()==0);
if(N>1){
N=Serial.parseInt();
Serial.print(N);
else if (N<1){
return;
Am I in the wrong order or using different commands?
What does a negative number look like when the user enters it and your Arduino receives it?
Paul
I can see no place in the program where you even test for a negative number. A negative number is one that is less than zero.
When inputting a negative number nothing happens and after if you input a positive program freeses
sortabler:
Yes, but how does a negative number look to you? Is it -1234 or is it 1234- or is it <1234>, or what?
Paul
On the monitor:
Enter value:
Thats it but if i input a positive first before a negative then
Enter value: 7
I guess you don't read replies...
aarg:
English is not the primary language?
Paul
I answered what my monitor shows after i input a number
//ive also tried
Int N;
N=Serial.parseInt ();
if(N>1){
Serial.println(N);
else if (N<1){
return;
void loop (){
// if i input a negative number first then positive nothing will print or return
//but if i input a positive first then it prints N
sortabler:
NO YOU DIDN"T ANSWER THE QUESTION!
How are you inputting a negative number?
Paul
-1 or ill input -2
Thank you for helping
