asksensors.com not sync
Hi. Hope that someone can help me.
I’m trying to test communications between an arduino uno with an esp8266-01 and Asksensors plattform.
I can stablish a connection with my wifi but when it trys to connect to api.asksensors.com it gives me an error.
Can someone help me find what is happening?
Thanks in advance
  Connect Arduino WiFi to AskSensors
 * Description:  This sketch connects the Arduino to AskSensors IoT Platform (https://asksensors.com) using an ESP8266 WiFi.
 *  Author: https://asksensors.com, 2018
 *  github: https://github.com/asksensors
#include <SoftwareSerial.h>
// serial config
#define     RX    11
#define     TX    12
SoftwareSerial AT(RX,TX);
// TODO: change user config
String ssid     = "ORTENSE"; //Wifi SSID
String password = "balasebolinhos4ever"; //Wifi Password
String apiKeyIn = "Plb8LCdXMTP0fgwq0vb4VG6e3U8U8urB"; // API Key
const unsigned int writeInterval = 25000; // write interval (in ms)
// ASKSENSORS API host config
String host = "api.asksensors.com";  // API host name
String port = "80";      // port
int AT_cmd_time;
boolean AT_cmd_result = false;
  // open serial
  Serial.println("*****************************************************");
  Serial.println("********** Program Start : Connect Arduino WiFi to AskSensors");
  AT.begin(115200);
  Serial.println("Initiate AT commands with ESP8266 ");
  sendATcmd("AT",5,"OK");
  sendATcmd("AT+CWMODE=1",5,"OK");
  Serial.print("Connecting to WiFi:");
  Serial.println(ssid);
  sendATcmd("AT+CWJAP=\""+ ssid +"\",\""+ password +"\"",20,"OK");
 // Create the URL for the request
  String url = "GET /write/";
  url += apiKeyIn;
  url += "?module1=";
  url += random(10, 100);
  Serial.println("********** Open TCP connection ");
  sendATcmd("AT+CIPMUX=1", 10, "OK");
  sendATcmd("AT+CIPSTART=0, \"TCP\",\"" + host +"\"," + port, 20, "OK");
  sendATcmd("AT+CIPSEND=0," + String(url.length() + 4), 10, ">");
  Serial.print("********** requesting URL: ");
  Serial.println(url);
  AT.println(url);
  delay(2000);
  sendATcmd("AT+CIPCLOSE=0", 10, "OK");
  Serial.println("********** Close TCP Connection ");
  delay(writeInterval);   // delay
// sendATcmd
void sendATcmd(String AT_cmd, int AT_cmd_maxTime, char readReplay[]) {
  Serial.print("AT command:");
  Serial.println(AT_cmd);
  while(AT_cmd_time < (AT_cmd_maxTime)) {
    AT.println(AT_cmd);
    if(AT.find(readReplay)) {
      AT_cmd_result = true;
    AT_cmd_time++;
  Serial.print("...Result:");
  if(AT_cmd_result == true) {
    Serial.println("DONE");
    AT_cmd_time = 0;
  if(AT_cmd_result == false) {
    Serial.println("FAILED");
    AT_cmd_time = 0;
Result of serial.print:
AT command:AT+CIPMUX=1
...Result:DONE
AT command:AT+CIPSTART=0, "TCP","api.asksensors.com",80
...Result:FAILED
AT command:AT+CIPSEND=0,58
...Result:FAILED
********** requesting URL: GET /write/Plb8LCdXMTP0fgwq0vb4VG6e3U8U8urB?module1=36
AT command:AT+CIPCLOSE=0
...Result:FAILED
