ASM can't reference a global variable [solved]
Can anyone please tell me what I’m missing here? I want to access a lookup table from inline code:
#include <Arduino.h>
static const int lookup[] = {1, 2, 3};
	asm volatile (
	  "ldi r30, lo8(lookup) \n"
But the linker tells me:
build/apc_test.o: In function loop': apc_test.cc:12: undefined reference to lookup’
collect2: error: ld returned 1 exit status
The link command was:
/usr/bin/avr-gcc -mmcu=atmega32u4 -Wl,-Os -Wl,–gc-sections -o build/apc_test.elf build/apc_test.o build/libarduino.a -lm
Just a guess but try removing static from the declaration.
Same error without the “static”.
Prefix an underscore.
still won't link:
undefined reference to `_lookup'
BTW I'm using version 4.8.2 of avr-gcc on a gentoo system.
what about that stuff you need at the end with the :-&r : stuff ?
And, lookup is an array name, not a variable.
It’s not my code, I’m trying to implement a program that uses the FHT library.
Here’s an snippet of the original source which causes problems:
asm volatile (
“clr r15 \n” // clear the null register
“ldi r16, “STRINGIFY(FHT_N/8)” \n” // prep loop counter
“mov r14,r16 \n”
“ldi r28, lo8(fht_input) \n” //set to beginning of data space
“ldi r29, hi8(fht_input) \n”
static const int lookup[] asm("lookup") __attribute__ ((used)) = {1, 2, 3};
Use "lookup" in your assembly.
That solved it.
Thank you so much.
Excellent. You are welcome.
