ASMG-MTB Servo to Arduino R3/R4
Hi all.
Very quick question, I am purchasing the ASMG-MTB Servo motor and it has its own built in driver, the external power input will be 24v.
I will be using and Arduino UNO R3 or R4 microprocessor and will be using a joystick. Joystick input into analog pins on the Arduino, output to the ASMG-MTB with be via a PWM output from the Arduino. I just wanted to make sure that the 'S' pin on the ASMG-MTB is the pin that I run my PWM output to. In the attached picture you can see the set up and it also states that the '+' pin is not required to be powered as the board already has an external 24v power source.
It then states that the GND pin is the negative signal line??
If I was using a POT no problem, fully understand the connections, the description for the PWM is a little unclear.
Has anyone here wired this particular servo with their Arduino UNO R3 or R4?
I just want to be 100% sure before connecting.
Thank you
I assume that say the '9' pin on the Arduino would run to the 'S' pin on the servo driver. The '-' pin on the driver would connect to the Arduino GND. Leaving the '+' pin on the driver board empty.
