ASP.NET and Arduino! (sending values to WEBpage)
I'm looking forward to send values from my arduino with ethernet to a ASP.NET written webpage, Any guidance where to start?
With understanding how client/server communication works. You can't send data to a server. You make a GET request, and supply information in the request that is needed to satisfy that request.
It matters not what language the server script is written in. It can be cgi, php, asp, asp.net, etc. The process is exactly the same.
How the script gets the data from the GET request, and how it deals with that data is specific to the language/script, and has NOTHING to do with the Arduino.
so from my webpage i must issue a HTTP get request towards arduino connecting to the internet using a Ethernet or GSM etc , is it ok? I was looking for a example on this
You can’t send data to a server. You make a GET request, and supply information in the request that is needed to satisfy that request.
The GET request contains the data being sent to the server. :roll_eyes:
Any examples
You do not send anything to a web page. A web page just contains information and URLs for the web client to act on. The web client (usually a browser) makes GET/POST connections to servers based on the information contained in a web page and then usually displays the info returned from the servers.
Any examples
In the IDE you have the Ethernet library with examples, the WebClient example is exactly what you're looking for.
That's what I said.
PaulS:
That's what I said.
You wrote "You can't send data to a server.". :roll_eyes:
Other than the data needed to fulfill a GET request, that is true. You know another way?
For a web server there is a POST request, which is much better suited to send bigger parts of data to the server. Web servers are not the only kind of server on the internet. For example log servers only receive data and almost never send some data back to the client.
The following is the code(of a GSM module that i recently bought) under which the ‘h’ switch case sends a http request so similarly i want to do something for my website and want some enlightening over this ,like in the code for sending the HTTP request (mySerial.println(“AT+HTTPREAD”):wink: , it reads the data of the website that i think means the data on that particular default webpage on the URL that we insert so here i want to mode/change it to HTTP write im sure in the SIM 900 documentation there would be such function that facilitates writing to the webpage but then where that data will go ? how im supposed to access the same?
/*Note: this code is a demo for how to using gprs shield to send sms message, dial a voice call and
  send a http request to the website, upload data to pachube.com by TCP connection,
  The microcontrollers Digital Pin 7 and hence allow unhindered
  communication with GPRS Shield using SoftSerial Library.
  IDE: Arduino 1.0 or later
  Replace the following items in the code:
  1.Phone number, don't forget add the country code
  2.Replace the Access Point Name
  3. Replace the Pachube API Key with your personal ones assigned
  to your account at cosm.com
#include <SoftwareSerial.h>
#include <String.h>
SoftwareSerial mySerial(7, 8);
  mySerial.begin(19200);               // the GPRS baud rate
  //after start up the program, you can using terminal to connect the serial of gprs shield,
  //if you input 't' in the terminal, the program will execute SendTextMessage(), it will show how to send a sms message,
  //if input 'd' in the terminal, it will execute DialVoiceCall(), etc.
  if (Serial.available())
    switch(Serial.read())
     case 't':
       SendTextMessage();
     case 'd':
       DialVoiceCall();
     case 'h':
       SubmitHttpRequest();
     case 's':
       Send2Pachube();
  if (mySerial.available())
    Serial.write(mySerial.read());
///SendTextMessage()
///this function is to send a sms message
void SendTextMessage()
  mySerial.print("AT+CMGF=1\r");    //Because we want to send the SMS in text mode
  delay(100);
  mySerial.println("AT + CMGS = \"+86138xxxxx615\"");//send sms message, be careful need to add a country code before the cellphone number
  delay(100);
  mySerial.println("A test message!");//the content of the message
  delay(100);
  mySerial.println((char)26);//the ASCII code of the ctrl+z is 26
  delay(100);
  mySerial.println();
///DialVoiceCall
///this function is to dial a voice call
void DialVoiceCall()
  mySerial.println("ATD + +86138xxxxx615;");//dial the number
  delay(100);
  mySerial.println();
///SubmitHttpRequest()
///this function is submit a http request
///attention:the time of delay is very important, it must be set enough
void SubmitHttpRequest()
  mySerial.println("AT+CSQ");
  delay(100);
  ShowSerialData();// this code is to show the data from gprs shield, in order to easily see the process of how the gprs shield submit a http request, and the following is for this purpose too.
  mySerial.println("AT+CGATT?");
  delay(100);
  ShowSerialData();
  mySerial.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");//setting the SAPBR, the connection type is using gprs
  ShowSerialData();
  mySerial.println("AT+SAPBR=3,1,\"APN\",\"CMNET\"");//setting the APN, the second need you fill in your local apn server
  delay(4000);
  ShowSerialData();
  mySerial.println("AT+SAPBR=1,1");//setting the SAPBR, for detail you can refer to the AT command mamual
  delay(2000);
  ShowSerialData();
  mySerial.println("AT+HTTPINIT"); //init the HTTP request
  delay(2000);
  ShowSerialData();
  mySerial.println("AT+HTTPPARA=\"URL\",\"www.google.com.hk\"");// setting the httppara, the second parameter is the website you want to access
  ShowSerialData();
  mySerial.println("AT+HTTPACTION=0");//submit the request
  delay(10000);//the delay is very important, the delay time is base on the return from the website, if the return datas are very large, the time required longer.
  //while(!mySerial.available());
  ShowSerialData();
  mySerial.println("AT+HTTPREAD");// read the data from the website you access
  delay(300);
  ShowSerialData();
  mySerial.println("");
  delay(100);
///send2Pachube()///
///this function is to send the sensor data to the pachube, you can see the new value in the pachube after execute this function///
void Send2Pachube()
  delay(100);
  ShowSerialData();
  mySerial.println("AT+CSTT=\"CMNET\"");//start task and setting the APN,
  ShowSerialData();
  mySerial.println("AT+CIICR");//bring up wireless connection
  delay(300);
  ShowSerialData();
  mySerial.println("AT+CIFSR");//get local IP adress
  delay(2000);
  ShowSerialData();
  mySerial.println("AT+CIPSPRT=0");
  delay(3000);
  ShowSerialData();
  mySerial.println("AT+CIPSTART=\"tcp\",\"api.cosm.com\",\"8081\"");//start up the connection
  delay(2000);
  ShowSerialData();
  mySerial.println("AT+CIPSEND");//begin send data to remote server
  delay(4000);
  ShowSerialData();
  String humidity = "1031";//these 4 line code are imitate the real sensor data, because the demo did't add other sensor, so using 4 string variable to replace.
  String moisture = "1242";//you can replace these four variable to the real sensor data in your project
  String temperature = "30";//
  String barometer = "60.56";//
  mySerial.print("{\"method\": \"put\",\"resource\": \"/feeds/42742/\",\"params\"");//here is the feed you apply from pachube
  ShowSerialData();
  mySerial.print(": {},\"headers\": {\"X-PachubeApiKey\":");//in here, you should replace your pachubeapikey
  ShowSerialData();
  mySerial.print(" \"_cXwr5LE8qW4a296O-cDwOUvfddFer5pGmaRigPsiO0");//pachubeapikey
  ShowSerialData();
  mySerial.print("jEB9OjK-W6vej56j9ItaSlIac-hgbQjxExuveD95yc8BttXc");//pachubeapikey
  ShowSerialData();
  mySerial.print("Z7_seZqLVjeCOmNbEXUva45t6FL8AxOcuNSsQS\"},\"body\":");
  ShowSerialData();
  mySerial.print(" {\"version\": \"1.0.0\",\"datastreams\": ");
  ShowSerialData();
  mySerial.println("[{\"id\": \"01\",\"current_value\": \"" + barometer + "\"},");
  ShowSerialData();
  mySerial.println("{\"id\": \"02\",\"current_value\": \"" + humidity + "\"},");
  ShowSerialData();
  mySerial.println("{\"id\": \"03\",\"current_value\": \"" + moisture + "\"},");
  ShowSerialData();
  mySerial.println("{\"id\": \"04\",\"current_value\": \"" + temperature + "\"}]},\"token\": \"lee\"}");
  ShowSerialData();
  mySerial.println((char)26);//sending
  delay(5000);//waitting for reply, important! the time is base on the condition of internet
  mySerial.println();
  ShowSerialData();
  mySerial.println("AT+CIPCLOSE");//close the connection
  delay(100);
  ShowSerialData();
void ShowSerialData()
  while(mySerial.available()!=0)
PaulS:
The problem is you put out confused and conflicting info in your problem solutions. :roll_eyes:
