Assign each Byte of a long or int a value
Hallo, I have just ordered my Arduino and started to work on programming a bit. Well... I am quite new to Microprocessors and my c-experince is some years back. So sorry if I got something wrong (just tell me).
My problem is: I get a datastream from a Sensor (Cloud Droplet Probe) as a 156byte hex stream via serial.read. The datatypes are mixed up (uint, ulong, char, (fancy 48 bit unsigned Extra long which wont be accessible I think). The data will be stored in an byte array of that size to manipulate it. Well, the problem is that the byte orders are a bit crossed like it seems. ulong has byteorder 2,3,0,1 for example. I would like to assigne these values from the fields of the array to their appropriate belonging in the variabales. For example: Bin2Count is given by byte 38 to byte 41 in the stream and so I would like to assign unsigned long Bin2Count[2]=data[38]; unsigned long Bin2Count[3]=data[39]; unsigned long Bin2Count[0]=data[40]; unsigned long Bin2Count[1]=data[41];
http://www.dropletmeasurement.com/manuals/Hardware%20Manuals/DOC-0029%20CDP%20Manual.pdf Page 33 shows the Byteorder.
Thanks in advance for your help.
I think appending to a string wouldn't work, because an unsigned long is an unsigned long and no string. Or maybe is it possible to create binary strings and append them? But as far as I remember conversions between characters and int weren't that nice.
You can declare union, look at this as example: http://arduino.cc/forum/index.php/topic,66206.0/topicseen.html
You could also use some bitshifting and OR a few bytes into a long:
uint32_t bigNumber = (data[40] << 0) | (data[41] << 8) | (data[38] << 16) | (data[39] << 24); // uint32_t is unsigned 32-bit long
Ah Ok, thank you (both). So I have two Ideas. The Union construct looks nice and quite clear in structure (although it's new to me).
Thanks a lot!
you could define functions to do the above bitshifting for every place where an ulong (U32) or uint (U16) is located, and then reading can be done in a loop as according to the spec the bincounts are at regular intervals.
Some snippets:
uint32_t getU32( int pos)
  uint32_t val = data[pos+2] | (data[pos+3] << 8) | (data[pos] << 16) | (data[pos+1] << 24);
  return val;
uint16_t getU16( int pos)
  uint16_t val = data[pos] | (data[pos+1] << 8); // might need to be swapped
  return val;
........ somewhere in your code ......
unsigned long binCount[29]; // array to hold all the binCounts.
for (int i=1; i<29; i++)
  binCount[i] = getU32(30 + 4*i);  // when i=1, it starts at pos = 34, when i=2, pos = 38 etc.
  Serial.println(binCount[i]);
// process the binCountsArray
uint16_t averageTransit = getU16(25);
robtillaart: you could define functions to do the above bitshifting for every place where an ulong (U32) or uint (U16) is located, and then reading can be done in a loop as according to the spec the bincounts are at regular intervals.
Some snippets: ....
Thanks robtillaart.... it confused me at first sight a bit, but it's clear now. That's been the way I had in mind (otherwise the code would be a bit crowded). I want to use a for loop to acess all bigger packages like BinCount and PBP data.
is there any reason that the 156-byte array can't be a structure? That is...
struct something { unsigned char upfront[40]; // the first 40 bytes (re-define as needed) unsigned long ulTheData; // the data I want (byte-flip as needed) .... (etc.) };
Then you reference the data directly, read directly into the structure or declare a pointer to it and assign the address of your data buffer like "something *pS = (something *)buffer;" and reference members like "pS->ulTheData". No more problems extracting things from the data using byte offsets.
And, if you need to byte-flip an unsigned long from 'high endian' to 'low endian' you can use this:
unsigned long byteflip(unsigned long TheValue) { union { unsigned char c[4]; unsigned long l; } a, b;
b.l = TheValue; a.c[0] = b.c[3]; a.c[1] = b.c[2]; a.c[2] = b.c[1]; a.c[3] = b.c[0];
return a.l; }
last I checked the above function compiles VERY TIGHT. Should be part of the library, maybe as 'ntohl' in the Ethernet library [that's where I made use of it, FYI]
A structure would be nice, but first I would like to keep it straight forward to get a running application to use for our probe (fog will be comming soon ;)) When that is running I take another board and go on to make the code smooth.
..want to have a basic running version first not to loose any time ;)
so, thanks for your suggestion. Could be something to try out later.
