Assign variables to char array
// send IMU data
void sendSensorData() {
  float eulers[3];
  float gyroacc[5];
  unsigned char accelCalibStatus = 0;   //Variable to hold the calibration status of the Accelerometer
  unsigned char magCalibStatus = 0;   //Variable to hold the calibration status of the Magnetometer
  unsigned char gyroCalibStatus = 0;    //Variable to hold the calibration status of the Gyroscope
  unsigned char sysCalibStatus = 0;   //Variable to hold the calibration status of the System (BNO055's MCU)
  // read orientation x, y and z eulers
  IMU.readEulerAngles(eulers[0], eulers[1], eulers[2]);
  // Send 3x eulers over bluetooth as 1x byte array
  imuCharacteristic.setValue((byte *) &eulers, 12);
  // read angular velocity around x, y and z-axis
  IMU.readGyroscope(gyroacc[0], gyroacc[1], gyroacc[2]);
  // read acceleration in x, y and z-direction
  IMU.readAcceleration(gyroacc[3], gyroacc[4], gyroacc[5]);
  gyroacc[3] = gyroacc[3] * 9.81;
  gyroacc[4] = gyroacc[4] * 9.81;
  gyroacc[5] = gyroacc[5] * 9.81;
  GyroAccCharacteristic.setValue((byte *) &gyroacc, 24);
  bno055_get_accelcalib_status(&accelCalibStatus);  //To read out the Acceleration Calibration Status (0-3)
  bno055_get_magcalib_status(&magCalibStatus);      //To read out the Magnetometer Calibration Status (0-3)
  bno055_get_magcalib_status(&gyroCalibStatus);     //To read out the Gyroscope Calibration Status (0-3)
  bno055_get_syscalib_status(&sysCalibStatus);      //To read out the System Calibration Status (0-3)
  unsigned char sendCalibration[] = {accelCalibStatus, magCalibStatus, gyroCalibStatus, sysCalibStatus};
  CalibrationCharacteristic.setValue((byte *) &sendCalibration, 4);
Dear Arduino community,
I am facing issue sending a 4-byte char array via BLE. The BLE function in general does it job. I suppose the problem lies in the char array itself. I have the variables for my calibration status which take numbers between 0 and 3. Those variables should be assigned to the array containing the 4 calibration status. This array is then send to the central. The central receives 0 0 0 0 whereas 3 3 3 3 would be expected for the calibrated sensor.
I am not very versed in C and the research about pointers did not lead me to a solution. Any help on this issue would be very much appreciated. Thanks upfront!
Kind regards
Chris
does How to create array to store pin assignments? address your issue
