assignment of function
What does that mean?????
Depends on the context.
Yes you can assign a function pointer value into a suitably typed variable. Perhaps you are asking what
is the syntax for the type of such a variable?
If you mean function pointer / variables, then you can do code like this:
//typedef = type definition
//void = return value, void = none
//FunctionTypeName = the name of the type
//int = arguments
typedef void (*FunctionTypeName)(int);
void aFunction(int value)
  //value is 123;
void CallFunction(FunctionTypeName theFunction)
  theFunction(123);
CallFunction(aFunction);
If you mean assign a return value you can do this:
int getTheValue()
  return 123; //Return a value
int theValue = getTheValue();
//theValue is now 123
If it is in an error message then it probably means you forgot the () on a function call.
youcefaek: you would do well to read How To Ask Questions The Smart Way.
