Hi!
I am trying to do a project - it's actually part of my thesis on the university.
The basics:
I'd like to control two stepper motors (I have two Nema23s).
Each of them move an installment in one direction forwards and backwards. - Basically a special XY-table.
The motors have to move the table in a special motion.
Go along one axis with little pauses in between,
one step along the secondary axis,
then come back along the primary axis.
One step along the secondary axis again, the same direction as before, etc.
You get the idea, I hope. Like a sweep.
The sweep has pauses, which are for ultrasonic measurements to be done (that's why I have the time intervals set up at the beginning of th ecode) - not part of my thesis.
After completing the sweep, the table needs to return to its original position.
I need to run this only once per power cycle - as I don't need the installment to run around like a maniac - so I put my code in the setup() section.
For the buttons: I'd like to use three buttons, functions below:
- One to move the installment - as long as pressed - along the primary axis (opposite direction) to setup a starting position along the primary axis.
- One to move the installment along the secondary axis. Goal: same as the one above.
- One to start the sweep (described above).
I am getting a bit confused how to do this, because every example I read about buttons and their usage used the buttons in the loop() section as their status needs to be checked repeatedly.
How can I get a basic loop for checking the buttons' status inside the setup() phase?
Project code in attached .txt file.
(The code would be too long to post here in "code" . Will try writing a procedure for movement to call in the setup() - e.g.: moveX(), moveY(), etc.)
Forgive me if any of the lines are not understandable, I had to translate the comments from Hungarian to English.
Thanks a lot for all the help in advance!
Cheers,
MacTavish
XY-axis.txt (4.79 KB)
