Good afternoon. Guys help me with the code. Program:
#include <AFMotor.h> //Link library for working with shield
// Plug motors to the terminal blocks M1, M2, M3, M4
AF_DCMotor motor1(1);
AF_DCMotor motor2(2);
AF_DCMotor motor3(3);
AF_DCMotor motor4(4);
void setup(){
// Set the maximum speed of the motor (similar work PWM)
motor1.setSpeed(255);
motor1.run(RELEASE);
motor2.setSpeed(255);
motor2.run(RELEASE);
motor3.setSpeed(255);
motor3.run(RELEASE);
motor4.setSpeed(255);
motor4.run(RELEASE);
void loop(){
digitalRead(31); //reading from 31 Pin
if (digitalRead(31) == HIGH) //condition if a high logic level
//moving forward
motor1.run(FORWARD); // Ask moving forward
motor2.run(FORWARD);
motor3.run(FORWARD);
motor4.run(FORWARD);
motor1.setSpeed(100); // Set the speed
motor2.setSpeed(100);
motor3.setSpeed(100);
motor4.setSpeed(100);
delay(5000);
// Stop motors
//moving backward
motor1.run(BACKWARD); // Ask moving backward
motor2.run(BACKWARD);
motor3.run(BACKWARD);
motor4.run(BACKWARD);
delay(4000);
// move left
motor1.run(FORWARD); // Ask moving forward 2 motors
// Stop all motors
/* Very not recommend sharply to switch the direction of rotation of the motor.
It is better to give a short period of time.*/
delay(5000);
// move left
// Stop all motors
delay(5000);
how can I make it to Arduino saw that if the pin three times will be a logic high level then the program will end because when I have the logic level low she turn left. And I need to make when it will be 3 times as high logic level motors stopped and not turned left to infinity.
P.S. Sorry immediately for my English I'm from Moldova
void setup(){
void loop(){
//moving forward
delay(5000);
// Stop motors
//moving backward
delay(4000);
// move left
// Stop all motors
delay(5000);
// move left
// Stop all motors
delay(5000);
void setup(){
void loop(){
//moving forward
delay(5000);
// Stop motors
//moving backward
delay(4000);
// move left
// Stop all motors
delay(5000);
// move left
// Stop all motors
delay(5000);
}[code]
how can I make it in to Arduino saw that if the pin three times will be a logic high level then the program will end because when I have the logic level low she turn left. And I need to make when it will be 3 times as high logic level motors stopped and not turned left to infinity. [/code]
Use a variable to count the number of times it's HIGH. If the variable is less than 3, do your turning, if 3 then don't do turning. Something like this:
int turnCount =0; //put this before setup()
void loop(){
if (digitalRead(31) == HIGH && turnCount <3){
turnCount++; //increase the count
// your current turn code here
//You will need to reset turnCount to 0 at some time
//but you've not given any information on how and when you want this.
// probably you'll want to do it in the else part.
No. The variable needs to count the number of times the pin BECOMES high.
OP: Look at the state change detection example, to see how to detect that a pin has BECOME high (or low), rather than that the pin IS high (or low). You want to take action when the pin changes state, not when it is in some state.
In the ideal world, yes, but his code has so many long delays in it (a total of 17 seconds), it won't make the slightest difference, unless he leans on the button for more than that length of time.
