hi every one I need assistance for mprls0300yg0001bb pressure sensor manufactured by Honeywell .we're encountering several problems like
1.The Readings of the actual data(correct pressure) is calculated after shift from correct pressure value17-20 seconds.
2.We are using the Atmega328p[Arduino nano] series Microcontroller chip to evaluate the pressure using the Spi interface. Thus we need to upgrade our Microcontroller with better processing power. If not how we can improve the response time?
3.In our experimental setup using an [htc manometer Pm-6205] as a reference if we are getting correct pressure but after a fraction of seconds it shift to a wrong value like negative=>10 after few reading it starts displaying correct pressure this problem occurs at specific pressure points every time.
the code is #include<Arduino.h>
#include<SPI.h>
double press_counts = 0; // digital pressure reading [counts]
double temp_counts = 0; // digital temperature reading [counts]
double pressure = 0; // pressure reading [bar, psi, kPa, etc.]
double pressure1 = 0;// error value pressure reading [bar, psi, kPa, etc.]
double temperature = 0; // temperature reading in deg C
double outputmax = 3774874;//15099494; // output at maximum pressure [counts]
double outputmin = 419429;//1677722; // output at minimum pressure [counts]
double pmax = 300; // maximum value of pressure range [bar, psi, kPa, etc.]
double pmin = 0; // minimum value of pressure range [bar, psi, kPa, etc.]
double percentage = 0; // holds percentage of full scale data
char printBuffer[200], cBuff[20], percBuff[20], pBuff[20], tBuff[20];
while (!Serial) {
delay(5000);
sprintf(printBuffer, "\nStatus Register, 24-bit Sensor data, Digital Pressure Counts,\
Percentage of full scale pressure,Pressure Output, Temperature\n");
Serial.println(printBuffer);
SPI.begin();
pinMode(10, OUTPUT); // pin 10 as SS
digitalWrite(10, HIGH); // set SS High
delay(1);
uint8_t data[7] = {0xFA, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}; // holds output data
uint8_t cmd[3] = {0xAA, 0x00, 0x00}; // command to be sent
SPI.beginTransaction(SPISettings(200000, MSBFIRST, SPI_MODE0)); //SPI at 200kHz
digitalWrite(10, LOW); // set SS Low
SPI.transfer(cmd, 3); // send Read Command
delay(10); // wait for conversion
SPI.transfer(data, 7);
SPI.endTransaction();
press_counts = data[3] + data[2] * 256 + data[1] * 65536; // calculate digital pressure counts
temp_counts = data[6] + data[5] * 256 + data[4] * 65536; // calculate digital temperature counts
//temperature = (temp_counts * 200 / 16777215) - 50; // calculate temperature in deg c
// percentage = (press_counts / 16777215) * 100; // calculate pressure as percentage of full scale
//calculation of pressure value according to equation 2 of datasheet
pressure = (((press_counts - outputmin) * (pmax - pmin)) / (outputmax - outputmin) + pmin);
pressure1 = pressure;
dtostrf(press_counts, 4, 1, cBuff);
dtostrf(percentage, 4, 3, percBuff);
dtostrf(pressure, 4, 3, pBuff);
dtostrf(temperature, 4, 3, tBuff);
The below code prints the raw data as well as the processed data
Data format : Status Register, 24-bit Sensor Data, Digital Counts, percentage of full scale
pressure, pressure output,
temperature
sprintf(printBuffer, "%x\t%2x %2x %2x\t%s\t%s\t%s\t%s \n", data[0], data[1], data[2], data[3],
cBuff, percBuff, pBuff, tBuff);
Serial.print(printBuffer);
delay(10);
datasheet
