I am trying to write code that performs the following: When I press a button (Pin2) the first time, I want Relay 1 on the Arduino relay shield to close for 1 second, and Relay 2 to latch on.
On the second press of the button, I want both relays to turn off. (Repeating this sequence)
When I press the button the first time, Relay 1 Turns on, then off, then on and off again. (Don't know where the other "ON-OFF" is coming from. Relay 2 does latch on.
When I press the button again, it repeats. I believe the "IF" statement may have an error. I'm using "RlyState" through the IF statement to determine when IF or ELSE is used.
Obviously, I am new to coding. Any assistance would be most appreciated. (I also used the example in Arduino IDE for debouncing) The code is below...
Sketch will be used to initiate Raspberry with a momentary 1 second output to Relay1 and a latching output to Relay 2
for the my Arcade
Pins are 4,7,8, & 12 for the 4 relays
const int pButton = 2; //Number of the pushbutton pin
const int Rly1 = 4; // Pin number for Relay 1 Raspberry
const int Rly2 = 7; // Pin number for relay 2 LED Latch
int buttonState = 0; // Variable for reading the pushbutton status
int RlyState = 0; // The current state of the output pin
int lastButtonState = 0; // The current reading of the input pin
long lastDebounceTime = 0; //The last time the output pin was toggled
long dBounceDelay = 50; // the debounce time, increase if chatters
pinMode(pButton, INPUT); //Initialize the Pbutton pin as an Input
pinMode(Rly1, OUTPUT); // Initialize Relay 1 pin as an Output
pinMode(Rly2, OUTPUT); //Initialize Relay 2 pin as an Output
int reading = digitalRead(pButton); // Read the state of the Pushbutton Pin
// Check if the Pushbutton is pressed
Serial.print("Button State is ");
Serial.println(buttonState);
Serial.print("RlyState is ");
Serial.println(RlyState);
Serial.print("reading is ");
Serial.println(reading);
delay(400);
if (reading != lastButtonState) {
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > dBounceDelay) {
buttonState = reading;
digitalWrite(Rly1, buttonState);
lastButtonState = reading;
if (buttonState == HIGH && RlyState == LOW) {
digitalWrite (Rly1, HIGH);
digitalWrite (Rly1, LOW);
digitalWrite (Rly2, HIGH);
digitalWrite (RlyState, HIGH);
else {
if (buttonState == HIGH && RlyState == HIGH) {
digitalWrite (Rly2, LOW);
digitalWrite (RlyState, LOW);
