I am currently working on a project involving the ICM42670P sensor,
and I have successfully implemented the code on an Arduino Mega 2560. However,
when I attempt to run the same code on the Seeed nRF52840 board,
I encounter issues and it does not function as expected. even when i scaneed to find address with it, I2C device not found.
Your topic has been moved. Please do not post in "Uncaqtegorized"; see the sticky topics in https://forum.arduino.cc/c/using-arduino/uncategorized/184 .
xfpd
August 21, 2024, 1:54pm
3
The physical pins are different in Arduino Mega2560 and Seeed nRF52840. Show a wiring diagram and the program code you are using. Describe what you expect to occur and what you observe.
elmiraab_90:
ICM42670P sensor
For reference:
The ICM-42670-P is a high performance 6-axis MEMS MotionTracking device that combines a 3-axis gyroscope and a 3-axis accelerometer
this is the code which i used and i double check the pin that should be worked, the main problem is int ret = IMU.begin(); not working
#include <Wire.h>
#include "ICM42670P.h"
ICM42670 IMU(Wire, 0); // Adresse 0x68
delay(2000);
while(!Serial);
Serial.println("Initializing ICM42670-P...");
if (ret != 0) {
Serial.print("ICM42670 initialization failed: ");
Serial.println(ret);
while(1);
IMU.startAccel(100, 16); // 100 Hz, ±16g
IMU.startGyro(100, 2000); // 100 Hz, ±2000 dps
delay(100);
inv_imu_sensor_event_t imu_event;
int ret = IMU.getDataFromRegisters(imu_event);
if (ret == 0) {
// Beschleunigung umrechnen (g)
float accelX = imu_event.accel[0] / 2048.0;
float accelY = imu_event.accel[1] / 2048.0;
float accelZ = imu_event.accel[2] / 2048.0;
// Gyroskop umrechnen (dps)
float gyroX = imu_event.gyro[0] / 16.4;
float gyroY = imu_event.gyro[1] / 16.4;
float gyroZ = imu_event.gyro[2] / 16.4;
// Werte im Format für den seriellen Plotter ausgeben
Serial.print(accelX); Serial.print(",");
Serial.print(accelY); Serial.print(",");
Serial.print(accelZ); Serial.print(",");
Serial.print(gyroX); Serial.print(",");
Serial.print(gyroY); Serial.print(",");
Serial.println(gyroZ); // Neue Zeile nach jedem Satz von Daten
Serial.print("Failed to read sensor data: ");
delay(10); // 100 Hz Loop-Rate
sterretje edit: code tags fixed
I've fixed your code tags.
It's not <CODE>
and <CODE/>
. It's either [code]
and [/code]
or three backticks (```
) on their own line before or after the code.
