Assistance Needed
Hi all,
I am Doing project on location tracking using inertial sensor, I have ADXL335 board. I am not good in programming. I have a task to make a programme to transfer the data from the board to the terminal device (siemens TC 65). In short , I have to make a programme so that my terminal device(siemens TC65) will read/receive the data from the ARDUIMU board.
Can anyone sort out my prob.:
There are several parts to your problem.
Connecting the ADXL335 to the Arduino correctly.
Reading data from the ADXL335 correctly, on the Arduino.
Sending the data read from the ADXL335 to the TC65.
Which parts are you having problems with?
Post some links to the devices in question, too (the ADXL335 you have and the TC65).
I have problem in both:
  1. I need a programme in C , so that i can read the data from the ADXL335 board.
  2. sending the data from ADXL335 board to the siemens terminal device tc 65.
How is the ADXL335 connected to the Arduino?
I connected my ADXL335 board to the computer through FTDI cable, Now my 1st task is to read the data from ADXL335 board.
Do you have an Arduino?
I have a ARDUIMU flat device and I need to read the data from it.
You can get the information about the device through this link
https://docs.google.com/View?id=dp66935_12c9b5bd2c#1_Introduction_to_ArduPilot_07_8773705245298064
No, I can't:
The proxy server is refusing connections
Firefox is configured to use a proxy server that is refusing connections.
  • Check the proxy settings to make sure that they are correct.
  • Contact your network administrator to make sure the proxy server is
    working.
I am new in this, I tried to upload the information in it, but it is not uploading it. Please try the link above .
To be honest, I don't think this ArduIMU isn't an Arduino. So I don't think we could help you here. (unless someone does no that ArduIMU board of course...) :-/
The board that we are disusing here is an inertial sensor, is it possible to read the data from that board by some codings??
:-[ I didn't look that good, it is related to Arduino and it is an expansion board.
Perhaps a little searching would do you good.. try this:
http://code.google.com/p/ardu-imu/wiki/StartedPage
I don't know anything about that sensor... I can't help you there..
Thanks David Perfors, I cleared my some of the doubts by these chat.
Best wishes
You do plan to work for it a bit yourself? I think no one will do work for free unless someone has done it before and is willing to share / help / mentor.
Good luck!
