Assistance with Bluetooth and RFID
I have an RFID reader hooked up to a bluetooth hm-10, but whenever I write the "cardid" it shows up on the recieving end as "0".
Here is my code:
#include <SD.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <SPI.h>
#include <Adafruit_PN532.h>
#define PN532_SCK  (2)
#define PN532_MOSI (3)
#define PN532_SS   (4)
#define PN532_MISO (5)
#define PN532_IRQ   (2)
#define PN532_RESET (3)
Adafruit_PN532 nfc(PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS);
SoftwareSerial mySerial(8,9);
String stringOne = "k";
#if defined(ARDUINO_ARCH_SAMD)
   #define Serial SerialUSB
#endif
void setup(void) {
  #ifndef ESP8266
    while (!Serial);
  #endif
  mySerial.begin(9600);
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    while (1);
  nfc.SAMConfig();
void loop(void) {
  uint8_t success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };
  uint8_t uidLength;
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
  if (success) {
    if (uidLength == 4)
      uint32_t cardid = uid[0];
      cardid <<= 8;
      cardid |= uid[1];
      cardid <<= 8;
      cardid |= uid[2];
      cardid <<= 8;
      cardid |= uid[3];
      mySerial.write(cardid);
    Serial.println("");
  delay(200);
I'm relatively inexperienced, so please try to explain it to me as clearly as possible.
Thanks!
mySerial.write() sends a single byte so you only get the lowest byte of cardid. Try mySerial.print(cardid) and you will get the ASCII version on the number.
If you want to send it as binary data, you need to use
mySerial.write(&cardid, 4 )
which send all 4 bytes of a uint32_t
thank you!
