Assistance with code for MD_MAX72XX matrix display
Hello,
I would appreciate someone assisting me with some code.
I am using an Arduino Uno to control a MAX72CC matrix display. The code below works well but I would like to modify it such that the message that appears across the display can vary depending upon certain conditions as defined in an if statement placed within the loop(). I have not had much luck doing this. Could someone assist me? Following is the code.
Thank you in advance for your assistance.
// MD_MAX72XX library can be found at https://github.com/MajicDesigns/MD_MAX72XX
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define HARDWARE_TYPE MD_MAX72XX::PAROLA_HW
#define MAX_DEVICES 8
#define PAUSE_TIME 5000
#define SCROLL_SPEED 50
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
//char Day = "Monday";
// HARDWARE SPI
MD_Parola P = MD_Parola(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
// SOFTWARE SPI
//MD_Parola P = MD_Parola(HARDWARE_TYPE, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
char *msg[] = // I WOULD LIKE TO BE ABLE TO MOVE THESE 5 LINES OF CODE DOWN INTO THE LOOP
"ABCDEFGHIJK",
"01234567890",
void setup(void)
// initialise the LED display
P.begin();
P.setZoneEffect(0, true, PA_FLIP_LR);
void loop(void)
// I WOULD LIKE TO PUT THE MSG[] HERE IN THE LOOP AS PART OF AN IF STATEMENT SO THE MESSAGE
// COULD CHANGE DEPENDING UPON CERTAIN CONDITIONS AS SPECIFIED IN THE IF STATEMENT.
// HOWEVER, PUTTING THE MSG[] HERE CAUSES AN ERROR.
static uint8_t cycle = 0;
if (P.displayAnimate())
// set up the string
P.displayText(msg[cycle], PA_CENTER, SCROLL_SPEED, PAUSE_TIME, PA_PRINT, PA_NO_EFFECT);
// prepare for next pass
cycle = (cycle + 1) % ARRAY_SIZE(msg);
void loop(void)
// You can't put anything other than a comment here, so it is not surprising you get an error.
Please remember to use code tags when posting code (you've been asked this before)
You probably want to put the msg definition after the '{' not before it.
AWOL: Thanks but I don't understand what you mean by "here". If you are referring to the loop(), this is where the main code is located.
You put a big SHOUTY comment that you had put something, possibly a variable definition, between "void loop (void)" and "{".
You can't do that. I thought I had mentioned that. Sorry if it wasn't clear.
AWOL, you hit the nail on the head. That was the issue.
Thank you!
Scott
