Thank you in advance for the help with all of this!
I have set up a website where I can control individually addressable LEDs via the internet using my nodemcu as the microcontroller/server. I have everything working great on my localhost but when I try to deploy it to heroku all of requests fail every time.
I have narrowed it down to 2 problems:
Problem 1: Heroku wants the requests to be in HTTPS but they are in HTTP
Possible Solution 1:
Use the WiFiClientSecure Library to convert the requests to HTTPS
I have not gotten this solution to work with the way my nodemcu is set up, and would greatly appreciate any advice on how to make it work.
This is the example that I found and was recommended by multiple articles
This example is making a get request on start up to the GitHub api
My goal is to make requests from my website to my nodemcu. I don't understand how I can make that happen.
Problem 2: Heroku doesn't like that I am making requests to a api that doesn't doesnt match its own query url
Possible Solution 2:
I have already implemented CORS on the Nodemcu
I created this function that gets pass into each route as shown below to allow it to be called from other query urls
This is what I initially had to do to get it working on my localhost
I feel like I need to do this same sort of thing but on the heroku side
void cors_set_access_control_headers()
Serial.println("cors_set_access_control_headers");
webServer.sendHeader("Access-Control-Allow-Origin", "*");
webServer.sendHeader("Access-Control-Max-Age", "10000");
webServer.sendHeader("Access-Control-Allow-Methods", "PUT,POST,GET,OPTIONS");
webServer.sendHeader("Access-Control-Allow-Headers", "*");
void run_server()
httpUpdateServer.setup(&webServer);
webServer.on("/all", HTTP_GET, []() {
cors_set_access_control_headers();
String json = getFieldsJson(fields, fieldCount);
webServer.send(200, "text/json", json);
I am using my nodemcu as a backend server that I am making get and post requests to from my full stack website. The examples that I found related to my problem seem to be pointing towards making requests from your nodemcu to an api, which is not what I am trying to do and I haven't found a way to utilize the same technique in my situation
This has been a problem that I have not been able to fix for too long now and I really appreciate any advice or help with all of this. Even coding structure tips. I'm trained in Javascript Full Stack Web development so my Arduino/C++ isn't my strong suit.
Here is the code for my main server.ino file
https://github.com/livingkurt/Glow-LEDs/blob/master/server/server.ino
routes.ino
https://github.com/livingkurt/Glow-LEDs/blob/master/server/routes.ino
wifi_setup.ino
https://github.com/livingkurt/Glow-LEDs/blob/master/server/wifi_setup.ino
I apologize if my code is messy, I've just been trying everything to get it to work.
