Assistance with printing an array.
Hi all,
I'm struggling to get a particular aspect of my program to work. Basically I want to print the entire array to a mysql database.
From what I can figure out it's only printing the single part of the array as it's in a loop. How do I print the entire array?
This is used in an RFID build and i'm trying to print the tag EPC to a sql database.
Devices used:
Arduino Uno WiFI Rev 2
Sparkfun Simultaneous RFID Reader
Code Below:
// Data Reading Below
  Serial.read(); //Throw away the user's character
  byte myEPC[12]; //Most EPCs are 12 bytes
  byte myEPClength;
  byte responseType = 0;
  byte data;
  while (responseType != RESPONSE_SUCCESS)//RESPONSE_IS_TAGFOUND)
    myEPClength = sizeof(myEPC); //Length of EPC is modified each time .readTagEPC is called
    responseType = nano.readTagEPC(myEPC, myEPClength, 500); //Scan for a new tag up to 500ms. NEEDED?
    Serial.println(F("Searching for tag"));
  Serial.print ("EPC= ");
  for (byte x = 0 ; x < myEPClength ; x++)
    if (myEPC[x] < 0x10) Serial.print(F("0"));
    Serial.print(myEPC[x], HEX);
    Serial.print(F(" "));
    //need to figure this out!!
    data = (myEPC[x], HEX);
  Serial.println(data);
  Serial.println(F(""));
  Serial.print("DeviceID= ");
  Serial.println (reader);
  //connect to server
  if (client.connect(server, 80)){
    client.print("GET /add_data.php?");
    client.print("value=");
    client.print(data);
    client.print("&location=");
    client.print(reader);
    client.println(" HTTP/1.1");
    client.print("Host: ");
    client.println(server);
    client.println("Connection: close");
    client.println();
    client.println();
    client.stop();
I'm very new to this so any help would be greatly appreciated.
This
does not do what you think that it does, but this does not solve your problem.
Okay. Do you have any suggestions as to what I could use?
How about deleting that line and just using (untested)
  Serial.println(myEPC[myEPClength-1], HEX);
Hint: This is quite different.
