Assistance with RPlidar - spins but doesn't provide data
Hello,
I'm new to using LiDAR - for this project, I'm working with a RPLiDAR. I'm using the attached code and the LiDAR spins, however, returns 0 for all values:
Edit: I'm using an Arduino Uno
#include <RPLidar.h>
// Create an instance of the RPLidar class
RPLidar lidar;
// Define the pin for controlling the LIDAR motor
#define RPLIDAR_MOTOR 7
  // Initialize Serial communication
  // Initialize the LIDAR
  lidar.begin(Serial);
  // Set the LIDAR motor pin as output
  pinMode(RPLIDAR_MOTOR, OUTPUT);
  // Start the LIDAR motor
  analogWrite(RPLIDAR_MOTOR, 255);
  delay(1000); // Wait for the motor to reach full speed
  // Start the LIDAR scanning
  lidar.startScan();
  if (lidar.waitPoint()) {
    // Get the current LIDAR data point
    float distance = lidar.getCurrentPoint().distance; // Distance value in mm
    float angle = lidar.getCurrentPoint().angle; // Angle value in degrees
    bool startBit = lidar.getCurrentPoint().startBit; // Whether this point is the start of a new scan
    byte quality = lidar.getCurrentPoint().quality; // Quality of the current measurement
    // Print the LIDAR data
    Serial.print("Distance: ");
    Serial.print(distance);
    Serial.print("mm");
    Serial.print(" | Angle: ");
    Serial.print(angle);
    Serial.print("°");
    Serial.print(" | Start Bit: ");
    Serial.print(startBit);
    Serial.print(" | Quality: ");
    Serial.println(quality);
I get the following output:
Distance: 0.00mm | Angle: 0.00° | Start Bit: 0 | Quality: 0
Thank you!
Are you using a logic level converter?
Maybe this will help:
I'm not, I've directly plugged the Slamtec Rplidar A1 to the Arduino Uno, but I've taken a look at the link you provided and I may learn something from here because to my knowledge the specific Rplidar I'm using doesn't require a logic converter.
Thanks for the link!
