AsyncDNSServer_STM32 for STM32 using built-in LAN8742A Ethernet
AsyncDNSServer_STM32 Library
How To Install Using Arduino Library Manager
Why do we need this Async AsyncDNSServer_STM32 Library
  • Using asynchronous network means that you can handle more than one connection at the same time
  • You are called once the packet is ready
  • After connecting to a UDP server as an Async Client, you are immediately ready to handle other connections while the Client is taking care of receiving the UDP responding packets in the background.
  • You are not required to check in a tight loop() the arrival of the UDP responding packets to process them.
  • Speed is OMG
Initial Releases v1.0.0
  1. Initial coding to port Develo's ESPAsyncDNSServer Library to STM32 boards using built-in LAN8742A Ethernet. More supports will be added gradually later, such as other Ethernet / WiFi shields.
  2. Add more examples.
  3. Add debugging features.
Currently Supported Boards
  1. Nucleo-144 (F429ZI, F746ZG, F756ZG, F767ZI)
  2. Discovery STM32F746G-DISCOVERY
  3. Any STM32 boards with enough flash/memory and already configured to run LAN8742A Ethernet.
Sample Code
This is the AsyncDNSServer_STM32 example
   Currently support
   1) STM32 boards with built-in Ethernet (to use USE_BUILTIN_ETHERNET = true) such as :
      - Nucleo-144 (F429ZI, F767ZI)
      - Discovery (STM32F746G-DISCOVERY)
      - STM32 boards (STM32F/L/H/G/WB/MP1) with 32K+ Flash, with Built-in Ethernet,
      - See How To Use Built-in Ethernet at (https://github.com/khoih-prog/EthernetWebServer_STM32/issues/1)
#include "defines.h"
#include <AsyncDNSServer_STM32.h>
#include <AsyncWebServer_STM32.h>
const byte DNS_PORT = 53;
IPAddress apIP;
AsyncDNSServer dnsServer;
AsyncWebServer server(80);
void handleNotFound(AsyncWebServerRequest *request)
  String message = "Hello World!\n\n";
  message += "URI: ";
  message += request->url();
  request->send(200, "text/plain", message);
  Serial.println("\nStart AsyncDNSServer_STM32 on " + String(BOARD_NAME));
  // start the ethernet connection and the server
  // Use random mac
  uint16_t index = millis() % NUMBER_OF_MAC;
  // Use Static IP
  //Ethernet.begin(mac[index], ip);
  // Use DHCP dynamic IP and random mac
  Ethernet.begin(mac[index]);;
  apIP = Ethernet.localIP();
  // modify TTL associated  with the domain name (in seconds)
  // default is 60 seconds
  dnsServer.setTTL(300);
  // set which return code will be used for all other domains
  // (e.g. sending ServerFailure instead of NonExistentDomain will reduce number of queries
  // sent by clients). Default is AsyncDNSReplyCode::NonExistentDomain
  dnsServer.setErrorReplyCode(AsyncDNSReplyCode::ServerFailure);
  // start DNS server for a specific domain name
  dnsServer.start(DNS_PORT, "*", apIP);
  server.onNotFound(handleNotFound);
  server.begin();
  Serial.print(F("HTTP EthernetWebServer is @ IP : "));
  Serial.println(apIP);
