void send_my_data()
if (client.connect(server, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET /search?q=arduino HTTP/1.1");
client.println("Host: www.google.com");
client.println("Connection: close");
client.println();
else {
// kf you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
while (true);
This is a function that is a part of the code below
#include <SPI.h>
#include <Ethernet2.h>
#include <avr/pgmspace.h>
#include <EEPROM.h>
#include <Uardecs_mega.h>
#include <Wire.h>
#define OPRMODE_ERR_SHT2xSENSERR 0x20000000 //0 01000 00000 0 0000 0000000000000000 //
char SHT2x_sensSts;
unsigned char SHT2x_errcount=0;
//IP reset jupmer pin setting
//IP
const byte U_InitPin = 3;
const byte U_InitPin_Sense=HIGH;
//Node basic infomation
const char U_name[] PROGMEM= "TempHumid Node";//MAX 20 chars
const char U_vender[] PROGMEM= "WARC/NARO";//MAX 20 chars
const char U_uecsid[] PROGMEM= "000000000000";//12 chars fixed
const char U_footnote[] PROGMEM= "SHT2x Sensor Node";
char U_nodename[20] = "node"; //MAX 19chars (This value enabled in safemode)
UECSOriginalAttribute U_orgAttribute;//
// html page1 setting
//Web
//Total number of HTML table rows.
//web
const int U_HtmlLine = 0;
struct UECSUserHtml U_html[U_HtmlLine]={
// UserCCM setting
// CCM
enum {
CCMID_InAirTemp,
CCMID_InAirHumid,
CCMID_InAirHD,
CCMID_cnd,
CCMID_dummy, //CCMID_dummy
//CCM
const int U_MAX_CCM = CCMID_dummy;
UECSCCM U_ccmList[U_MAX_CCM];
//CCM
const char ccmNameTemp[] PROGMEM= "Temperature";
const char ccmTypeTemp[] PROGMEM= "InAirTemp";
const char ccmUnitTemp[] PROGMEM= "C";
const char ccmNameHumid[] PROGMEM= "Humid";
const char ccmTypeHumid[] PROGMEM= "InAirHumid";
const char ccmUnitHumid[] PROGMEM= "%";
const char ccmNameHD[] PROGMEM= "HumidDiff";
const char ccmTypeHD[] PROGMEM= "InAirHD.mIC";
const char ccmUnitHD[] PROGMEM= "g m-3";
const char ccmNameCnd[] PROGMEM= "NodeCondition";
const char ccmTypeCnd[] PROGMEM= "cnd.mIC";
const char ccmUnitCnd[] PROGMEM= "";
void UserInit(){
U_orgAttribute.mac[0] = 0x00;
U_orgAttribute.mac[1] = 0x00;
U_orgAttribute.mac[2] = 0x00;
U_orgAttribute.mac[3] = 0x00;
U_orgAttribute.mac[4] = 0x00;
U_orgAttribute.mac[5] = 0x01;
UECSsetCCM(true, CCMID_InAirTemp, ccmNameTemp, ccmTypeTemp, ccmUnitTemp, 29, 1, A_10S_0);
UECSsetCCM(true, CCMID_InAirHumid, ccmNameHumid, ccmTypeHumid, ccmUnitHumid, 29, 1, A_10S_0);
UECSsetCCM(true, CCMID_InAirHD, ccmNameHD, ccmTypeHD, ccmUnitHD, 29, 2, A_10S_0);
UECSsetCCM(true, CCMID_cnd , ccmNameCnd , ccmTypeCnd , ccmUnitCnd , 29,3, A_10S_0);
void OnWebFormRecieved(){
void UserEverySecond(){
U_ccmList[CCMID_cnd].value=0;
if(SHT2x_errcount>3)
SHT2x_errcount=4;
U_ccmList[CCMID_cnd].value|=OPRMODE_ERR_SHT2xSENSERR;
//------------------------------------------------------(3)
static char count=0;
count++;
if(count %3==1)
double t=SHT2x_GetTemperature();
Serial.print("TEMPERATURE using t=SHT2x_GetTemperature():");
Serial.print (t);
double rh=SHT2x_GetHumidity();
if(SHT2x_sensSts)
SHT2x_errcount++;
else{
SHT2x_errcount=0;
U_ccmList[CCMID_InAirTemp].value=(long)(t*10);
Serial.print("TEMPERATURE using U_ccmList[CCMID_InAirTemp].value=(long)(t*10):");
Serial.print (U_ccmList[CCMID_InAirTemp].value);
U_ccmList[CCMID_InAirTemp2].value=(long)(t*10);
U_ccmList[CCMID_InAirQuality].value= 0;
U_ccmList[CCMID_InAirHumid].value=(long)(rh*10);
double humidpress=6.1078*pow(10,(7.5*t/(t+237.3)));
double humidvol=217*humidpress/(t+273.15);
U_ccmList[CCMID_InAirHD].value=(100-rh)*humidvol;//
if(SHT2x_errcount)
U_ccmList[CCMID_InAirTemp].flagStimeRfirst=false;
U_ccmList[CCMID_InAirTemp2].flagStimeRfirst=false;
U_ccmList[CCMID_InAirQuality].flagStimeRfirst=false;
U_ccmList[CCMID_InAirHumid].flagStimeRfirst=false;
U_ccmList[CCMID_InAirHD].flagStimeRfirst=false;
/* to get attribute and type data
// HTTPGetFormDataEDITCCMPage HTTPGetFormDataEDITCCMPageTRIAL;
// Serial.print("U_ccmList[CCMID_InAirTemp].baseAttribute[AT_ORDE]");
// Serial.println(U_ccmList[CCMID_InAirTemp].baseAttribute[AT_ORDE]);
// Serial.print("U_ccmList[CCMID_InAirTemp].typeStr");
// Serial.println(U_ccmList[CCMID_InAirTemp].typeStr);
void UserEveryMinute(){
send_my_data();
void UserEveryLoop(){
void loop(){
UECSloop();
delay(5000);
void setup(){
Wire.begin();
UECSsetup();
delay(5000);
//----------------------------------------SHT2x
#define eSHT2xAddress 0x40
#define eTempHoldCmd 0xE3
#define eRHumidityHoldCmd 0xE5
#define eTempNoHoldCmd 0xF3
#define eRHumidityNoHoldCmd 0xF5
double SHT2x_GetHumidity(void)
return (-6.0 + 125.0 / 65536.0 * (double)(SHT2x_readSensor(eRHumidityHoldCmd)));
double SHT2x_GetTemperature(void)
return (-46.85 + 175.72 / 65536.0 * (double)(SHT2x_readSensor(eTempHoldCmd)));
uint16_t SHT2x_readSensor(uint8_t command)
uint16_t result;
Wire.beginTransmission(eSHT2xAddress);
Wire.write(command);
delay(5);
SHT2x_sensSts=Wire.endTransmission();
if(SHT2x_sensSts){return 0;}
Wire.requestFrom(eSHT2xAddress, 3);
if(Wire.available()==3)
result = ((Wire.read()) << 8);
result += Wire.read();
result &= ~0x0003; // clear two low bits (status bits)
return result;
SHT2x_sensSts=4;
return 0;
The problem is that WHEN THE FUNCTION send_my_data() IS CALLED, OTHER OPERATIONS OF THE CODE STOPS UNTIL THE FUNCTION IS EXECUTED. I DON'T WANT THIS TO HAPPEN. WHAT SHOULD I DO TO ENSURE THAT OTHER PROCESSES OF THE CODE CONTINUES AFTER THE FUNCTION send_my_data() IS CALLED? HERE send_my_data() IS JUST FOR ILLUSTRATION, THERE WILL BE OTHER THINGS IN IT TOO.
UARDECS_MEGA-master.zip (58.4 KB)
