Asynchronous REST API call + LED matrix display
Hey everyone,
I am a newbie in the Arduino world so sorry if this post sounds dumb :confused:
I am working on a personal project using an Arduino Uno + Ethernet shield and an Adafruit LED matrix panel.
I query (every x s) a REST API than runs on my local network and display the retrieved data on the LED Matrix (scrolling).
Query + JSON parsing works properly but takes some time (around 5s).
I don't want to block the display from scrolling while retrieving the data.
So ... ideally I would need two threads runnings in parallel ... which I understood was not possible since the Arduino is single-threaded.
I stumbled upon many articles/posts referencing Timer Interrupts, Protothreading, Arduino Thread libraries ... but I must admit that I am bit lost here.
Could anyone give me some insight ?
Thanks a lot !
JC
really 5 seconds - that's a lot of time... is that really that complex what you need to parse? or did you set a timeOut to 5 seconds and you wait for timeOut??
Hi J-M-L,
This is actually another issue I am facing :confused: .
The message is not complex at all and the timeout is not reached.
The 5s are spent reading the ethernet client. I suspect an issue with the way I am buffering (I use Serial.readBytes).
Thanks
Jad
Without seeing your code? Yeah, it's too complex and slow. Hope that helps.
