AsyncWebServer_Teensy41 library
How To Install Using Arduino Library Manager
This library is based on, modified from:
to apply the better and faster asynchronous feature of the powerful ESPAsyncWebServer Library into Teensy 4.1 using built-in QNEthernet
Why Async is better
- Using asynchronous network means that you can handle more than one connection at the same time
- You are called once the request is ready and parsed
- When you send the response, you are immediately ready to handle other connections while the server is taking care of sending the response in the background
- Speed is OMG
- Easy to use API, HTTP Basic and Digest MD5 Authentication (default), ChunkedResponse
- Easily extensible to handle any type of content
- Supports Continue 100
- Async WebSocket plugin offering different locations without extra servers or ports
- Async EventSource (Server-Sent Events) plugin to send events to the browser
- URL Rewrite plugin for conditional and permanent url rewrites
- ServeStatic plugin that supports cache, Last-Modified, default index and more
- Simple template processing engine to handle templates
Currently supported Boards
- Teensy 4.1 using QNEthernet Library
Changelog
Releases v1.4.1
- Initial porting and coding for Teensy 4.1 using built-in QNEthernet
- Bump up version to v1.4.1 to sync with AsyncWebServer_STM32 v1.4.1
Debug Termimal Output Samples
1. Async_AdvancedWebServer on Teensy4.1 QNEthernet
Following are debug terminal output and screen shots when running example Async_AdvancedWebServer on Teensy4.1 using Built-in Ethernet and QNEthernet Library demonstrate the operation of AsyncWebServer.
Start Async_AdvancedWebServer on TEENSY 4.1 with Teensy4.1 QNEthernet
AsyncWebServer_Teensy41 v1.4.1
Initialize Ethernet using DHCP => Connected! IP address:192.168.2.107
HTTP EthernetWebServer is @ IP : 192.168.2.107
2. MQTTClient_Auth on Teensy4.1 QNEthernet
Following is debug terminal output when running example MQTTClient_Auth on Teensy4.1 using Built-in Ethernet and QNEthernet Library.
Start MQTTClient_Auth on TEENSY 4.1 with Teensy4.1 QNEthernet
Attempting MQTT connection to broker.emqx.io...connected
Message Send : MQTT_Pub => Hello from MQTTClient_Auth on TEENSY 4.1 with Teensy4.1 QNEthernet
Message arrived [MQTT_Pub] Hello from MQTTClient_Auth on TEENSY 4.1 with Teensy4.1 QNEthernet
