AT Command response into variable
Hi, i am developing a project that send data from sensor to web server through SIM800l GSM/GPRS module. I want to know how can I get AT command response and save it into a variable.
For example, I want to know the signal strenght using AT command "AT+CSQ". In serial monitor I can see the response, but i want to take that response and display in a screen or light on a red led if signal = 0 or green led if signal > 0.
The response of AT+CSQ command is: "+CSQ: 0,0" (I have no signal), so I want to light on a red LED in this case.
Portion of my code:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(8, 9);
void setup(){
  mySerial.begin(9600);
  //with this, I can see response in serial monitor.
  //I want to take the response into a String variable
  mySerial.write("AT+CSQ\r");
void loop(){
  if (mySerial.available()){
    Serial.write(mySerial.read());
  if (Serial.available()){
    while(Serial.available()) {
      mySerial.write(Serial.read());
    mySerial.println();
Thank you very much.
If there is a response, do nothing more than read and print the response.
Saving the response in an array, and resetting the array index at the appropriate time, seems far more useful to me.
