A little while ago i had a bluetooth module (HC05) and an arduino mega 2560 , i tried using writing some AT commands onto the module (when i plugged in the arduino i disconnected the vcc of the module , pressed the button on it and while pressing i plugged in the vcc of the module and it went into AT mode - it started blinking every 2 seconds) and it worked fine , i was able to change the module's name and password and everything. Recently without changing the arduino or the module , i tried the same method and it didn't work ! (even used the same script for the commands) , can anyone help me find out why this doesn't work ? i tried changing the arduino and the module itself , and it still doesn't work.
- The script i used for the AT commands is attached below.
AtCommands.ino (320 Bytes)
