#include <SoftwareSerial.h>
//Create software serial object to communicate with SIM800L
SoftwareSerial mySerial(3, 2); //SIM800L Tx & Rx is connected to Arduino #3 & #2
//Begin serial communication with Arduino and Arduino IDE (Serial Monitor)
//Begin serial communication with Arduino and SIM800L
mySerial.begin(9600);
Serial.println("Initializing...");
mySerial.println("AT"); //Once the handshake test is successful, it will back to OK
updateSerial();
mySerial.println("AT+CMGF=1"); // Configuring TEXT mode
updateSerial();
mySerial.println("AT+CNMI=1,2,0,0,0"); // Decides how newly arrived SMS messages should be handled
updateSerial();
updateSerial();
void updateSerial()
while (Serial.available())
mySerial.write(Serial.read());//Forward what Serial received to Software Serial Port
while(mySerial.available())
Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
ı use arduino nano and sim 800l
serial monitor just
"" Initializing... ""
A line like above does not send data to Serial; if you want to see it on the Serial Monitor as well, you need to add a Serial.print / Serial.println() after it.
Are you certain that you have cross connected module Tx to Arduino soft serial Rx and module Rx to Arduino soft serial Tx and are using the voltage divider on the Arduino Tx to module Rx?
The software serial constructor is referenced to the Arduino pins. What module pin is connected to Arduino pin3 and what module pin is connected to Arduino pin 2?
