I'm very new to electronics so perhaps I am missing something simple.
I am working on building a 4 legged robot controlled by Arduino Uno. It is connected to:
- 8 servo motors. There is an external 6v 3000mAh battery to supply power to the servos.
- 1 ESP8266-01 with 5V adapter. This takes in requests from a web app and moves the robot according to the request.
- ArduCam OV2640 mini 2mp plus
There is a common ground between the servos, arduino, external battery, camera, and ESP8266.
Complete code here: https://bitbucket.org/ftso/quadraped-robot/src/master/
Previously I was able to successfully use software serial on pins 11 and 12 to send AT commands to the ESP-01 and process requests from a web app to move the robot. The servos uses pins 2-9 for the data wire. I am trying to add ArduCam related code now. ArduCam uses SPI and I2C. I have the CS pin for ArduCam on pin 10. I noticed that after I added a call to SPI.begin(), the software serial stops successfully sending commands to the ESP-01 (or the ESP-01 isn't able to receive the commands). On some occasions, one of the servos also starts overheating (wire from the external battery starts smoking) even though the servos are not moving. Could someone provide some guidance? Attaching my main.cpp below:
#include <Arduino.h>
#include <Servo.h>
#include <walk.h>
#include <SoftwareSerial.h>
#include <server_receiver.h>
#include <camera.h>
void server_configure();
CommandAndValue getCommandAndValue();
String sendCommand(String cmd, int timeout);
void sendResponse(String msg);
void camera_configure();
Robot robot;
ArduCAM ARDU_CAMERA(OV2640, CS_PIN);
// RX (connected to TX of ESP8266), TX (connected to RX of ESP8266)
SoftwareSerial softwareSerial(12, 11);
// Configure CAMERA
camera_configure();
// Configure ESP-01
server_configure();
// calibrate motors to rest position.
robot.attach();
goToRestPos(robot);
robot.detach();
delay(2000);
Serial.println("EVERYTHING GO");
CommandAndValue commandAndValue = getCommandAndValue();
if (commandAndValue.command != "") {
Serial.println(commandAndValue.command);
Serial.println(commandAndValue.value);
/*if (commandAndValue.command == "CAMERA_CAPTURE") {
camera.captureImage(&server_receiver);
robot.attach();
for (int i = 0; i < commandAndValue.value; i++) {
if (commandAndValue.command == "FORWARD") {
walkOneStep(robot);
} else if (commandAndValue.command == "ROTATE_RIGHT") {
turnRightOneStep(robot);
} else if (commandAndValue.command == "ROTATE_LEFT") {
turnLeftOneStep(robot);
robot.detach();
sendResponse("OK");
// Esp8266 Code //
String sendCommand(String cmd, int timeout) {
yield();
softwareSerial.print(cmd); // Send "AT+" command to module
Serial.println("cmd: " + cmd);
String response = "";
long int time = millis();
while (time + timeout > millis()) {
yield();
while (softwareSerial.available()) {
yield();
char c = softwareSerial.read();
response += c;
Serial.println(response);
return response;
void server_configure() {
softwareSerial.begin(9600);
sendCommand("AT+RST\r\n", 7000); // Reset the ESP8266
sendCommand("AT+CWMODE=1\r\n",1000); // Set the ESP8266 to work as a station.
sendCommand("AT+CWJAP=\"Burrito\",\"Melodyisthebest\"\r\n", 7000); // Setup Wifi
sendCommand("AT+CIFSR\r\n", 2000); // Display IP address.
sendCommand("AT+CIPMUX=1\r\n",2000); // Enable multiple connections
sendCommand("AT+CIPSERVER=1,80\r\n",2000); // Open server mode on port 80.
CommandAndValue getCommandAndValue() {
String incomingRequest = "";
yield();
CommandAndValue commandAndValue;
if (softwareSerial.available()) {
yield();
incomingRequest = softwareSerial.readString();
Serial.print("Received request: ");
Serial.println(incomingRequest);
if (incomingRequest.indexOf("FORWARD") != -1) {
commandAndValue.command = "FORWARD";
commandAndValue.value = getIntCommandValue(getCommand(incomingRequest, "FORWARD"));
return commandAndValue;
} else if (incomingRequest.indexOf("ROTATE_RIGHT") != -1) {
commandAndValue.command = "ROTATE_RIGHT";
commandAndValue.value = getIntCommandValue(getCommand(incomingRequest, "ROTATE_RIGHT"));
} else if (incomingRequest.indexOf("ROTATE_LEFT") != -1) {
commandAndValue.command = "ROTATE_LEFT";
commandAndValue.value = getIntCommandValue(getCommand(incomingRequest, "ROTATE_LEFT"));
} else if (incomingRequest.indexOf("CAMERA_CAPTURE") != -1) {
commandAndValue.command = "CAMERA_CAPTURE";
commandAndValue.value = 0;
void sendResponse(String msg) {
String responseheader = "HTTP/1.1 200 OK\r\nAccess-Control-Allow-Origin: *\r\nContent-Type: text/plain\r\nConnection: close\r\nContent-Length: 2\r\n\n"+msg+"\r\n";
int len = responseheader.length();
String openChannel = "AT+CIPSEND=0,"+String(len)+"\r\n";
sendCommand(openChannel, 2000);
delay(3000);
softwareSerial.print(responseheader);
delay(3000);
sendCommand("AT+CIPCLOSE=0\r\n", 1000);
// ArduCAM Code //
void camera_configure() {
uint8_t vid, pid;
uint8_t temp;
#if defined(__SAM3X8E__)
Wire1.begin();
#else
Wire.begin();
#endif
// Set CS pin as output
pinMode(CS_PIN, OUTPUT);
digitalWrite(CS_PIN, HIGH);
// initialize SPI:
SPI.begin();
// //Reset the CPLD
// ARDU_CAMERA.write_reg(0x07, 0x80);
// delay(100);
// ARDU_CAMERA.write_reg(0x07, 0x00);
// delay(100);
// while (1) {
// //Check if the ArduCAM SPI bus is OK
// ARDU_CAMERA.write_reg(ARDUCHIP_TEST1, 0x55);
// temp = ARDU_CAMERA.read_reg(ARDUCHIP_TEST1);
// if (temp != 0x55) {
// Serial.println(F("ACK CMD SPI interface Error!END"));
// delay(1000); continue;
// } else {
// Serial.println(F("ACK CMD SPI interface OK.END")); break;
// while (1) {
// //Check if the camera module type is OV2640
// ARDU_CAMERA.wrSensorReg8_8(0xff, 0x01);
// ARDU_CAMERA.rdSensorReg8_8(OV2640_CHIPID_HIGH, &vid);
// ARDU_CAMERA.rdSensorReg8_8(OV2640_CHIPID_LOW, &pid);
// if ((vid != 0x26 ) && (( pid != 0x41 ) || ( pid != 0x42 ))) {
// Serial.println(F("ACK CMD Can't find OV2640 module!"));
// else {
// Serial.println(F("ACK CMD OV2640 detected.END")); break;
// ARDU_CAMERA.set_format(JPEG);
// ARDU_CAMERA.InitCAM();
// ARDU_CAMERA.OV2640_set_JPEG_size(OV2640_320x240);
// delay(1000);
// ARDU_CAMERA.clear_fifo_flag();
// delay(1000);
Serial.println("CAMERA READY");
Thank you!
