AT commands
Hello,
I am having a compilation problem in regards to AT commands which include multiple commas and speech marks.
This is the code I have written.
#include <SoftwareSerial.h>
const byte rx = 7 ;
const byte tx = 8 ;
SoftwareSerial myserial(rx, tx);
  myserial.begin(115200); //Initialize virtual serial port
  Serial.begin(115200); //Initialize Arduino default serial port
  gsm_setup() ;
  Serial.println("Sending an AT command...");
void gsm_setup() {
    myserial.println("ECHO") ; // Removes ECHO
    delay(500) ;
    myserial.println("AT+CPIN=0000") ; // Entres SIM PIN No
    delay(10000) ;
    myserial.println("AT+CGDCONT=1,"IP","orange"") ; // Connect to ORANGE APN
    delay(5000) ;
    myserial.println("AT+NETOPEN") ; // Opens network
    delay(1000) ;
    myserial.println("AT+CIPOPEN=1","TCP","172.111.250.41","666") ; // Connect to VPN TCP Server
    delay(5000) ;
    myserial.println("AT+CIPSEND=0,5") ; // Send 5 characters
    delay(5000) ;
    myserial.println("READY") ; // Send ready
    delay(1000) ;
    myserial.println("0x1a") ; // Ctlr + Z to send message
    delay(1000) ;
And the error messages I get are the following:
C:\Users\mateusz.winter\OneDrive - RIOU GESTION\Beehive\Code\GSMTEST\TEST\TEST.ino: In function 'void gsm_setup()':
TEST:30:39: error: inconsistent user-defined literal suffixes 'IP' and 'orange' in string literal
TEST:30:48: error: unable to find string literal operator 'operator""IP' with 'const char [15]', 'unsigned int' arguments
TEST:34:65: error: no matching function for call to 'SoftwareSerial::println(const char [13], const char [4], const char [15], const char [4])'
In file included from C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Stream.h:26:0,
                 from C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/HardwareSerial.h:29,
                 from C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Arduino.h:233,
                 from sketch\TEST.ino.cpp:1:
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:77:12: note: candidate: size_t Print::println(const __FlashStringHelper*)
     size_t println(const __FlashStringHelper *);
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:77:12: note:   candidate expects 1 argument, 4 provided
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:78:12: note: candidate: size_t Print::println(const String&)
     size_t println(const String &s);
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:78:12: note:   candidate expects 1 argument, 4 provided
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:79:12: note: candidate: size_t Print::println(const char*)
     size_t println(const char[]);
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:79:12: note:   candidate expects 1 argument, 4 provided
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:80:12: note: candidate: size_t Print::println(char)
     size_t println(char);
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:80:12: note:   candidate expects 1 argument, 4 provided
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:81:12: note: candidate: size_t Print::println(unsigned char, int)
     size_t println(unsigned char, int = DEC);
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:81:12: note:   candidate expects 2 arguments, 4 provided
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:82:12: note: candidate: size_t Print::println(int, int)
     size_t println(int, int = DEC);
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:82:12: note:   candidate expects 2 arguments, 4 provided
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:83:12: note: candidate: size_t Print::println(unsigned int, int)
     size_t println(unsigned int, int = DEC);
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:83:12: note:   candidate expects 2 arguments, 4 provided
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:84:12: note: candidate: size_t Print::println(long int, int)
     size_t println(long, int = DEC);
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:84:12: note:   candidate expects 2 arguments, 4 provided
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:85:12: note: candidate: size_t Print::println(long unsigned int, int)
     size_t println(unsigned long, int = DEC);
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:85:12: note:   candidate expects 2 arguments, 4 provided
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:86:12: note: candidate: size_t Print::println(double, int)
     size_t println(double, int = 2);
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:86:12: note:   candidate expects 2 arguments, 4 provided
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:87:12: note: candidate: size_t Print::println(const Printable&)
     size_t println(const Printable&);
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:87:12: note:   candidate expects 1 argument, 4 provided
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:88:12: note: candidate: size_t Print::println()
     size_t println(void);
C:\Users\mateusz.winter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Print.h:88:12: note:   candidate expects 0 arguments, 4 provided
exit status 1
If you need to include speech marks in the output you need to escape them by preceding them with a \ character
What should the output from
myserial.println("AT+CIPOPEN=1","TCP","172.111.250.41","666") ; // Connect to VPN TCP Serveractually look like ?
Hi HeliBob good to hear from you again,
Basically what it should do is AT+CIPOPEN=0,“TCP”,“172.111.250.41”,666 then return to send the command.
Hope it answers the question
Try this
  while(!Serial);
  Serial.println( "AT+CIPOPEN=0,\"TCP\",\"172.111.250.41\",666");
I get no errors on that line now but now I get an error with myserial.println("AT+CGDCONT=1,"IP","orange"") ; // Connect to ORANGE APN
I would assume from your modification it would be like myserial.println("AT+CGDCONT=1,"IP","orange"") ; is that correct?
Once that is sold I will try and it and get back to you
Try it in my example program so that you can see what it is doing
It works fine now.
Thanks!
