If you have one of those ebay boards and want to use the extra memory on board here is how to do it. The memory is apparently good for 1 million write cycles and 100 years! Much better than the 1024 bytes EEPROM on the Atmega328 and much more plentiful - 32K bytes!
Here are the routines to use it, hope they are useful to someone, as I had to search high a low to try to understand how the thing works. The code is self explanatory - I have hardcoded a retry count of 10 which has passed my read/write test.
#define AT24C32_I2C_ADDRESS 0x50 // the I2C address of Tiny RTC AT24C32 EEPROM
void Tiny_RTC_DS1307_24C32::EEPROM_write_byte( unsigned int uiAddress, byte bData )
int iCount=0;
do
Wire.beginTransmission(AT24C32_I2C_ADDRESS);
Wire.write((byte)(uiAddress >> 8)); // MSB
Wire.write((byte)uiAddress); // LSB
Wire.write(bData);
} while (Wire.endTransmission()!=0 && ++iCount<10);
void Tiny_RTC_DS1307_24C32::EEPROM_read_byte( unsigned int uiAddress, byte *pbData )
int iCount=0;
do
Wire.requestFrom(AT24C32_I2C_ADDRESS,1);
*pbData = Wire.read();
