Atan2() Function Taking Long Time
Hi guys I am using the atan2() function in my code but it takes almost 1ms to run. Is there a faster way to do it or if I paste the code for the atan2 in my code that should run faster right? Is the atan2 available open source.
You may lose the tiny overhead of a call if it gets inlined, but no, wrong.
Wrong. If it takes x amount of time to execute when the code is in a library, it will take x amount of time to execute if the code is not in a library.
Thanks would appreciate your help on how to implement it faster.
Johnny1010: Thanks would appreciate your help on how to implement it faster.
Use a faster processor. Don't you think that if the atan2() function could be made faster, it would have been?
Google "CORDIC"
Try one of the trig identities.
I found out doing your own "approximated" functions work much faster. I think last time I borrowed some code from java trigonometry implementation as it was much faster than the c function.
Thanks guys the cordic thing has worked well
